Old 05-10-2020, 11:01 PM   #21
bdtutton
Default Re: Lighting for speedometer and gas gauge
I was the one that originally started this thread. Per the instructions in this thread, I replaced the 6v bulb with a 12v bulb and the light is bright enough to light the speedometer, but is not so bright that it causes the excessive reflections the bright 6v bulb did. Thank you for the idea everyone...
bdtutton is offline   Reply With Quote
Old 05-11-2020, 02:21 PM   #22
mngreen
mngreen's Avatar
Originally Posted by CarlG View Post
Which LED bulb did you use?
CarlG--if you're running 12V this is the ticket ($6.95):
https://www.superbrightleds.com/more...fit/3698/8009/
I have one in my dash rail and is a PERFECT FIT and am very happy with it. I also put them in the cowl lamps and tail light.
Mike Green
mngreen is offline   Reply With Quote
Old 05-11-2020, 03:31 PM   #23
Y-Blockhead
Y-Blockhead's Avatar
Carl, This is the LED I used for my dash light in my Town Sedan. Available 12v. It is forward firing so the cover defuses the light some. I use the natural white one, not as harsh as the cool white. Appears they are out of stock, tho.
https://www.superbrightleds.com/more...mens/2438/766/
