Old 08-15-2015, 11:55 AM   #1
JAKEFORD
Default Ford Anglia/Prefect/Model A
I have 3 old prefect engines in various states of disassembly. But I don't have the distributor or Carb or Oil Pan. I was told the model A distributor would fit the Prefect. I think it is the 1.7L 10 hp model and is probably from 1948-50.
I would like to get one of these running again but don't know where to find parts. I have tried Small Ford Spares in the UK to no avail and others with the same result.
This English engine and car were a scaled down model A ford. I had one in high school and it was a terrific car but need a lot of attention. I remember one time we packed in 5 adults and 6 small kids and went out for ice cream!
Can anyone help?
JAKEFORD is offline   Reply With Quote
Old 08-15-2015, 12:28 PM   #2
Steve Plucker
Default Re: Ford Anglia/Prefect/Model A
Try Berts in Denver, CO USA (See Sticky for information).
Also there were about 4-5 different varities of oil pans that were used on the Model A engine.
http://www.plucks329s.org/studies/studies.htm
Pluck
Old 08-15-2015, 12:53 PM   #3
Juggler
Juggler's Avatar
Here's a few more to try in UK
http://www.belcherengineering.co.uk/
http://www.fsoc.co.uk/
http://poppartsplus.com/index.php/parts/electrical/ Have dizzy and recon carb listed.
https://www.ford-aquaplane.co.uk/ If you want to hop them up a bit
If that lot doesn't get you sorted then the things you are after turn up on eBay UK fairly often
http://www.ebay.co.uk/sch/i.html?_od...&_sacat=131090
Cheers
Juggs
Juggler is offline   Reply With Quote
Old 08-15-2015, 01:08 PM   #4
JAKEFORD
Thanks for all the good information.
Old 08-16-2015, 12:43 AM   #5
updraught
updraught's Avatar
The Prefect distributor was a common replacement for the A one as it had centrifugal advance, so no levers and things.
Belcher Engineering looks interesting:
http://www.belcherengineering.co.uk/...tion/index.php
updraught is offline   Reply With Quote
Old 08-16-2015, 06:32 AM   #6
leakers
It would help if you filled out your location in your profile, if you are in the USA , call Anglia Obsolete in Vista California...they have everything you need.
http://www.angliaobsolete.com
leakers is offline   Reply With Quote
