Old 07-01-2022, 09:27 AM   #1
Brian SATX
Brian SATX's Avatar
Default Toe in on front in
I know there is a way to check toe in using a 2x4 and some rubber bands but I cannot find it. Can anyone direct me to a place that has the procedure in writing/diagrams? Thanks in advance.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 07-01-2022, 09:39 AM   #2
eagle
eagle's Avatar
Default Re: Toe in on front in
I just rolled the car on clean flat concrete for a couple wheel revolutions, then used a tape measure on the rim. Of course you have to first make sure your rims are true. I set mine for 1/8" toe in. This was about 10 years ago. Tire wear is even and it drives very well.
Old 07-06-2022, 05:14 PM   #3
petritl
Brian,
If you are still in need, I have a toe measurement tool you can borrow.
Tad Petrie
petritl is offline   Reply With Quote
