10-27-2020, 11:29 AM | #1 |
Model B Fuel Pump
Hi, is it possible to run the stock B fuel pump with any kind of full flow oil filter ?
10-27-2020, 11:47 AM | #2 |
Re: Model B Fuel Pump
Am I correct that you see the two components as incompatible because they typically occupy the same physical space?
10-27-2020, 12:01 PM | #3 |
My guess is no although you could probably install a remote filter kit. Or make your own like one member did on here. I think it was Al in NY?
10-27-2020, 12:11 PM | #4 |
Maybe the Stipe adapter? Shows as out of stock, but you could call and see what the situation is.
https://www.specialtymotorcams.com/d...er-prelief-017 |
10-27-2020, 04:15 PM | #5 |
I have the Specialty Motor Cams Oil Filter Kit for B and run the stock B pump. It is very well made.
10-27-2020, 06:40 PM | #6 |
Other manufacturers of filter kits make use of the unused fuel pump opening on side of B block to return the oil to the oil pan from an external mounted oil filter. In these cases you can not run a stock B fuel pump with this oil filter. Last edited by Benson; 10-27-2020 at 10:20 PM. |
10-27-2020, 10:10 PM | #7 |
My remote full flow oil filter dumps the filtered oil into the valve chamber.
Alaskan A's Antique Auto Mushers of Alaska Model A Ford Club of America Model A Restorers Club Antique Automobile Club of America Mullins Owner's Club Last edited by CarlG; 10-28-2020 at 12:51 PM. |
10-28-2020, 08:27 AM | #8 | |
This is filter I spoke about in previous post for Model B which uses (that is covers up) the fuel pump "port" to mount filter. Looks maybe home brew. Also has bypass valve that dumps to timing cover. Filtered Pressure oil goes into stock Model B engine "oil Galley". Last edited by Benson; 10-28-2020 at 08:34 AM. |
10-28-2020, 09:39 AM | #9 |
I would think that the side cover mounted filter should work on a B.
https://www.snydersantiqueauto.com/P...earchByKeyword
