02-11-2014, 07:38 PM | #1 |
gps
okay guys how do you rig up a gps on 6volts
trev,, whats life "TOUGH" whats tough ' LIFE" |
02-11-2014, 07:47 PM | #2 |
Re: gps
i put one in my `37 1/2 ton, 6 volt positive ground. a GPS runs on 5 volts, but it has to be negative ground, so i used a "convertor". it changes 6 volt positive ground to 12 volts negative ground, it is an e-bay item, costs about $50.00. anyway, that`s how i did it.
tom |
02-11-2014, 08:21 PM | #3 |
Re: gps
so where on ebay ive tried converters,,,inverters all get id cars
02-11-2014, 08:40 PM | #4 |
Re: gps
e-bat item #
271380501537 tom |
02-11-2014, 08:48 PM | #5 |
Re: gps
Our GPS will run 3 hours on a full charge so just turn it on occasionally when on a trip in our 46. Then I have a charger that plugs in to 110 in the motel and good to go the next day.
John |
02-11-2014, 09:02 PM | #6 |
Re: gps
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
02-11-2014, 11:46 PM | #7 |
Re: gps
Trev, I have been using my 12V Garmin GPS on 6V for several years. I bought a cigar lighter socket/receptacle and hard wired it for correct polarity with the GPS power cord that has a cigar lighter plug on one end. I used a piece of heat shrink tubing to cover the outer socket/receptical housing to keep it from shorting to positively grounded parts on the car.
I also have a small 12V battery power pack that I can use to temporarily power my cell phone, digital camera, ipad or GPS.
02-12-2014, 12:10 AM | #8 |
Re: gps
I like to use Microsoft Streets and Trips on my lap top for GPS since I'm more used to reading maps.
The computer battery lasts about 4 hours then, if I need to, I can plug it into my tire pump that's 12 volt rechargeable with a cigarette lighter socket on it. Can be used for 12 volt or 110 volt with the little 75 watt inverter shown.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
02-12-2014, 08:25 AM | #9 |
Re: gps
I have 6 to 12 converters on all myT's and run them off old Radio Shack converters which you can find on ebay a lot cheaper than the $50 plus rig that shows up regularily. They can be wired for either polarity. You just have to watch on a regular basis and they will come up.
02-12-2014, 08:31 AM | #10 |
Re: gps
I cut the power cord and reversed the wires and run it on my '40 pickup. I marked the cord and don't take it out of the truck so I don't use it on 12 v.
02-12-2014, 08:42 AM | #11 |
Re: gps
The only problem with running the 12 volt GPS on 6 volts with reversed wires is with a generator at idle the voltage gets to low to the GPS and it shuts down and has to be restarted. This occurs in towns just when you need it. With a good alternator you don't get this problem. A small 6 to 12 volt converter works good. These are still available and are about 3"s square. G.M.
www.fordcollector.com |
02-12-2014, 11:18 AM | #12 |
Re: gps
As they say, your results may vary. But in the last four years using my GPS on six volts I have not experienced any problems. I have a Garmin.
02-12-2014, 12:12 PM | #13 | |
Re: gps
02-12-2014, 12:19 PM | #14 |
Re: gps
I have a small gell battery that is used for under water cameras. Its 12 volt and I put it under the seat with a female lighter pulg in on it. I use it for the gps and charger for cell phone. Lasts along time on a charge. About $15.00 for battery.
02-12-2014, 04:12 PM | #15 |
Re: gps
Trev go to a Jaycar store ,get a part AA0264, I have them in my cars,you then get a 12v output to use for a Twoway radio or GPS.
Lawrie |
02-12-2014, 05:32 PM | #16 |
Re: gps
John, thanks for choosing Optima I don't have a 6-volt vehicle, but I do use GPS without needing to plug in. I downloaded the free mobile navigation app, Waze and run it on my iPhone. The app does use a lot of battery, but I also have a Mophie case, which gives me several hours on Waze at a minimum. I used to use a regular gps device, but I've found the real-time traffic updates (as well as law enforcement & road hazard updates) and re-routing ability to be incredibly reliable and useful. It also has a speedometer feature.
Jim McIlvaine eCare Manager, OPTIMA Batteries www.pinterest.com/optimabatteries |
02-12-2014, 06:09 PM | #17 | |
Re: gps
I'd be careful about trusting Pepe as the navigator. Even with the screen right in front of him, he doesn't seem to care where he's going. Viva Pepe!
Nothing wrong with it except for the name on the front. Alex |
02-12-2014, 06:14 PM | #18 |
Re: gps
02-12-2014, 06:40 PM | #19 |
Re: gps
JT FORD, what gel battery are you using? I was thinking that this could also be a solution for running a 12V car stereo. Some of these batteries are getting pretty small and would be easier to conceal than a regular 12V car battery and could be maintained with a Battery Maintainer between uses.
02-12-2014, 10:21 PM | #20 |
Re: gps
This battery is a MK 6"x 4-1/2" x 2-1/2" Cabela's, Bass Pro, and automotive supply stores sell them. I have had mine for 7-8 years. I lay it under the front seat. 2 amp
charger is best for it. JT |
