Old 09-02-2013, 04:50 AM   #1
37coop
37coop's Avatar
Default flathead pcv valve kit by jamco ...any good?
hi guys ,on my 8ba engine it smokes a bit from the oil filler ,the engine is out of the truck with the oil pan ,heads and manifold off ,after advice from the barn I,m not going to do a job on it I intend to clean it up and put it back in the truck and see how it goes (I imported it to here in the u.k but have not been able to drive it due to brakes ,steering etc ).....the question is has anybody used the pcv valve kit made by jamco ,it replaces the vent tube and connects to the vacuum pipe and sucks into the carb,seems a simple answer to a smokey engine bay , what do you think or am I wasting my time and cash? , any advice would be appreciated. cheers jim.
37coop is offline   Reply With Quote
Old 09-02-2013, 06:06 AM   #2
Tony, NY
Default Re: flathead pcv valve kit by jamco ...any good?
http://www.jamcosuspension.com/produ...productID/1504
Tony, NY is offline   Reply With Quote
Old 09-02-2013, 06:26 AM   #3
oldskool
oldskool's Avatar
i have one on my 41 w/ 50 merc engine even though i have no blow by it a good idea to have one seeing most later cars have them
oldskool is offline   Reply With Quote
Old 09-02-2013, 07:13 AM   #4
rrthiv
rrthiv's Avatar
Just cut the draft tube piece that goes into the intake and get a pcv rubber grommet and a gm pcv cost me 10 bucks.
rrthiv is offline   Reply With Quote
Old 09-02-2013, 11:00 AM   #5
4t8v8
Ditto. Works great.
4t8v8 is offline   Reply With Quote
Old 09-02-2013, 11:06 AM   #6
4t8v8
If it helps any, I used a bushing #42054 from the "Help!" rack. The valve is a Fram PCV306. Slid the draft tube out of the manifold and slid the bushing in. Fit perfectly.
Old 09-02-2013, 11:52 AM   #7
Chris Nelson
Chris Nelson's Avatar
I have used the Borg Warner #382 PCV valve and inserted it in a late Ford grommet from the rack at the auto supply store and plumb it to the intake manifold under the carb. The grommet has to fit where the road draft tube goes into the manifold. The reasoning for the Borg Warner unit is the valve operating range;
closed at 16-18 in hg
floats at 8-16 in hg
open at 1-6 in hg
I have used this in several 8BA engines and it works great.
Chris Nelson is offline   Reply With Quote
Old 09-02-2013, 12:02 PM   #8
buddridge
Have one on my 37 with 8BA since 2000.............no problems.
buddridge is offline   Reply With Quote
Old 09-02-2013, 03:55 PM   #9
37coop
37coop's Avatar
thanks guys , I went on their site that tony kindly posted and bought one ,I would have tried to make one but I,m up to my ears in work so this time I took the easy way out , thanks again , cheers jim.
Old 09-02-2013, 04:35 PM   #10
justpassinthru
justpassinthru's Avatar
I have the same one that Jamco sells but I got it from a fellow in Canada. A while back there were some issues with Jamco filling orders so I went with him. He sells on EB.
Nice machined spacer with a o-ring that actually fit for once.
I plumbed mine into both sides of the manifold so it would draw from all the cylinders instead of just a few. I have seen cars that had PCV plumbed into the intake manifold in one runner and foul the plug in that cylinder. I didnt want that to happen.
Bill
THIS ISN'T THE KIND OF ANSWER
I WAS LOOKING FOR OUT OF YOU!
justpassinthru is offline   Reply With Quote
Old 09-02-2013, 04:58 PM   #11
flatheadz-forever
helpful thread
flatheadz-forever is offline   Reply With Quote
Old 09-02-2013, 06:12 PM   #12
41panelmark
41panelmark's Avatar
Anybody know if this can be used on 40/41 blocks and or the 59a? Any one making something for those?
41panelmark is offline   Reply With Quote
Old 09-03-2013, 04:14 AM   #13
37coop
37coop's Avatar
Bill
I must say your engine really is a work of art and thanks for your comments , cheers jim.
Old 10-23-2013, 08:41 PM   #14
wfritchen
Originally Posted by Chris Nelson View Post
I have used the Borg Warner #382 PCV valve and inserted it in a late Ford grommet from the rack at the auto supply store and plumb it to the intake manifold under the carb. The grommet has to fit where the road draft tube goes into the manifold...
Can you provide more detail on "late Ford grommet"?
Thanks,
Walt
wfritchen is offline   Reply With Quote
Old 10-23-2013, 09:19 PM   #15
VeryTangled
VeryTangled's Avatar
37coop X2.
justpassingthru, Hubba Hubba! Sexaaaay. Flathead Porn.
'37coop, if I could make a request... Come back later and let us know about your experiences. I think you've done the right thing, it had to be less than $75 to give it a try. If it works, it's money well ventured.
-VT/JeffH
VeryTangled is offline   Reply With Quote
Old 10-24-2013, 12:07 PM   #16
Chris Nelson
Walt;
The grommet that I used is for the PCV valve on a 1975 to 1994 Ford or Mercury. It fits right in the road draft tube hole in the intake manifold. The Borg Warner #382 PCV valve fits that grommet and has the correct rating for the flathead.
Old 10-24-2013, 03:19 PM   #17
37coop
37coop's Avatar
Originally Posted by VeryTangled View Post
37coop X2.
-VT/JeffH
it arrived and looks good and fits nicely but sadly I,m having to have a rebore ,new pistons ,rings shells etc so the easy/cheaper way out of using the pcv system to help rid of fumes is not to be ,although I will still fit it .....jamco easy to deal with ,no issues and about $60 including shipping to u.k ....our post office lost it and then i got charged a nonsense amount of tax and handling after they found it 6 weeks later , grrrrrrr.
Old 10-24-2013, 07:19 PM   #18
russcc
Great post on eliminating the darn draft tube, how & what to use. Fordbarn and it's innovative members at it's best. Thank you.
russcc is offline   Reply With Quote
Old 10-24-2013, 09:06 PM   #19
51504bat
51504bat's Avatar
Lots of issues with Jamco filling orders. Lots of threads on the H.A.M.B. about this. Buyer beware.
