Old 09-20-2021, 01:09 PM   #1
aandkt
Default 1936 fuel sender access
I have a 36 Cabriolet with no apparent access to the sender in the trunk.
Does anyone have any info on a 1936 fuel sender as to access and repair?
Thanks
aandkt is offline   Reply With Quote
Old 09-20-2021, 02:23 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: 1936 fuel sender access
There should be an access hole to the sender in the floorboard, just over the sender. There will be a cover over the hole that is held down by a screw. Look again.
Old 09-20-2021, 07:09 PM   #3
terry
On my 36 sedan i have to pull the vertical portion of the back seat forward to get at it. It is a little tight, as i recall, but doing this with the rear seat is necessary to get at that screw that holds down the plate above the gas tank. Terry
terry is offline   Reply With Quote
Old 09-21-2021, 10:03 PM   #4
aandkt
It appears that my floor was replaced
Can you send me a photo of the location of the screw and plate to help me locate where to cut a hole to access the sending unit or measurements of nearby landmarks
Thanks
Old 09-22-2021, 06:31 PM   #5
terry
I think that i was too quick with the info about getting to the gas tank sender cover. Your 36 Cabriolet doesn't even have a back seat. I'm not sure a photo of my sender opening would give you a reference point for your vehicle. But, I'll try to get a photo out to you tomorrow. On my sedan, scooting underneath and getting my head up high enough, i can see the top of the gas tank and where the sender sits. i hope someone can chime in here as to how to get at your sender. The logical place would be under rumble seat. Terry
Old 09-23-2021, 07:17 PM   #6
terry
One picture shows the tape measure coming from the left side wall. Other picture shows the tape coming from the back wall which is very close to the back cross member of the chassis. The metal trap door is a little to the right of center on the metal floor.
Old 10-28-2021, 02:35 PM   #7
aandkt
Thanks. I am trying to install a ground and need to make an opening ro work om the swnder.
Old 10-28-2021, 09:41 PM   #8
oleschool36ford
oleschool36ford's Avatar
Open your rumble seat about half way and look down on back side of lid and there should be a cover over the fuel sender.
oleschool36ford is offline   Reply With Quote
Old 07-24-2022, 01:16 PM   #9
aandkt
I have removed the rumble seat and lid totally and there is no access hatch. I must have a replacement trunk floor.
Is your gas filler on the right or left tail light?
Mine is on the left (Drivers) side.
Old 07-25-2022, 01:04 AM   #10
deuce lover
deuce lover's Avatar
Here is a pic of the fuel sender access location on the floor on an original LHD car
Old 08-28-2022, 10:00 AM   #11
aandkt
Thanks to all who sent info and pictures, I was able to cut a hole in my trunk floor in just about thr right spot and size to work on the sending unit. Both gauge and sender seem to function independently and grounded but together the gauge reads "EMPTY"
Old 09-20-2022, 05:44 PM   #12
aandkt
I removed the sender and bench tested it. From the 12v battery hooked up in the car I ran a positive jumper through a reducer to the 1936 gauge which was grounded to the grounded sender.
The tank was full and the gauge reads 1/2.
Any suggestions ???
Thanks
Old 09-20-2022, 06:44 PM   #13
Lawson Cox
Lawson Cox's Avatar
Gradually bend the arm on the float until the gauge reads the way you want it to. That's about the only way to do it.
Old 09-22-2022, 09:57 PM   #14
aandkt
The 1/2 reading is with the arm (Float) all the way at the top of its range.
Old 09-23-2022, 09:28 AM   #15
rotorwrench
rotorwrench's Avatar
Is the an original King Seeley sending unit or is this an aftermarket rheostat type replacement? The modern replacements won't give the indicator gauge a correct signal like the OEM King Seeley type will. The KS units are current pulse type systems where all the modern stuff are resistance based systems where the sender resistance range has to meet the input range of the indicator. A modern instrument that is within the range of the replacement type sending unit is the only thing that will give a correct reading.
Condition of the float on the sender can be a concern. Brass floats leak sometimes and get heavy or don't float at all.
Old 09-23-2022, 07:00 PM   #16
terry
The original float on my 36 was cork that had some thing on it that looked like varnish. I
found it hard to get an original float, so used a rubber float that I think was for a 32 Ford.
Don't bend the lever arm until you are sure it's not the original King Seely unit. That could make things worse. With the orig sending unit, it's probably not the lever arm that is the pbm. terry
Old 11-13-2022, 05:12 PM   #17
aandkt
I finally got the Bob Drake sending unit in the mail and bench tested it with the 12 v and a reducer. With all the float way down to the lowest point that it will go to I get a 1/4 tank reading on two different '36 gauges. When I lift the float up it rockets past the full reading. When I let it go down it very slowly goes down to 1/4 again.
Any ideas?
Thanks
Old 11-13-2022, 07:20 PM   #18
Lawson Cox
Lawson Cox's Avatar
Any ideas?
Thanks
Ain't modern technology great? NOT.
Old 11-14-2022, 01:19 PM   #19
JayChicago
JayChicago's Avatar
Any ideas?
Even with float all the way down, this sender is allowing too much current for the gauge. You can add a resistor or two in series to the wire just ahead of the sender. Try 5 ohm or 10 ohm. (Buy them on line, they are cheap) Trial and error to see what works with that sender. Then when accurate near empty, won’t be accurate over full scale. But accuracy when tank is about empty is what’s important to me.
Old 12-23-2022, 06:23 PM   #20
aandkt
Jay - You say" You can add a resistor or two in series to the wire just ahead of the sender. Try 5 ohm or 10 ohm."
Do you mean before the gauge or before the sender as you said?
