Old 09-22-2020, 05:18 PM   #1
Ronnieroadster
Ronnieroadster's Avatar
Default Flathead dry sump oil pump two stage
City: Wallingford
State: Ct
Price: 225.00
Here's an interesting oil pump for a serious completion engine. Made by the Madis Engineering Co from Bellflower California. This pump is NOS it mounts directly to the Ford flathead three bolt front cover. It drives directly by the cam having the correct offset male tang. The front of the pump has the female drive offset slot for the distributer. Its simply placed between the distributer and the front cover. The geared pump shaft is supported by high quality ball bearings.
Besides the pump I also have an early 59A type oil pan that's flat on the bottom the sump having been removed with an outlet for the suction side of the pump.
I'm asking $225.00 for the pump shipping would be extra. If interested in the pump and the pan lets talk please send me a PM and I will contact you.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder and Driver of the First Ford Flathead bodied roadster to run 200 MPH Record run July 13, 2018 LTA timing association 200.921 from a standing start in one and a half miles burning gasoline.
Ronnieroadster is offline   Reply With Quote
Thread Tools
Display Modes
