08-11-2020, 07:48 PM | #1 |
Speedo cable
On my new purchase the car had broken speedo cable. Replaced with new insert. That lasted 18 miles. I noticed the outer cable spiral was once possibly slightly kinked at both ends then tape covering the split cable. Replaced the entire cable assembly. That lasted 80 miles before it broke. All 3 times the insert was broken at the tranny end. What could be the problem?
PS when working the speedo is smooth running and not jumpy or noisy |
08-11-2020, 09:59 PM | #2 |
Re: Speedo cable
Email Leonard he rebuilt my speedometer head, resealed it, new glass, new bezel, and painted it. Works great. Mine stopped and broke the cable also, no jumping, no noise, was working fine and just stopped. Sent it to Leonard, fast repair and return.
[email protected] Leonard Nichols, 126 Beckwith st, Gouverneur N,Y, 13642
"I'd rather be sitting in my A Model thinking about God, then in church thinking about my A Model." |
08-11-2020, 10:23 PM | #3 | |
Re: Speedo cable
08-12-2020, 10:42 AM | #4 |
Re: Speedo cable
If being used, if they get noisy/jumpy, you can try forcing some oil/lube down the cable from the speedometer end if it is the cable. Otherwise the speedo has to be serviced. |
