08-22-2019, 11:34 AM | #1 |
Model A Ford Fender Debate
I am helping a friend with his 31Tudor, it has maroon fenders. The explanation was that this was done for Mexico or arid temperature locations. Is this correct or the previous owners justification for it. Was it a true Ford production for that market.
08-22-2019, 11:55 AM | #2 |
Re: Model A Ford Fender Debate
As far as I know, ALL fenders were painted black from the factory. Check your friend's fenders carefully for signs of a repaint.
08-22-2019, 12:08 PM | #3 |
I agree with Mike !!!
08-22-2019, 12:43 PM | #4 |
As far as I know (and not to put your friend down) that is not true.
"The more things change, the more they stay the same." |
08-22-2019, 12:44 PM | #5 |
Ford Dearborn and the assembly agencies around the US didn't have variation on fender & running board apron unless it would have been a special fleet order. Most fleet orders would have been commercial vehicles in that era. Mexico had an assembly agency beginning in 1925 but they were likely building up knock down kits from the US in that time frame. There is not much information about the early production in Mexico so it's hard to say. I wouldn't say no but I would say that it is doubtful.
The fender wells in the body were even painted black to match after a time. The early cars had body color there but customers complained since it was visible through the wire wheels and dealers started painting those areas for the customers until Ford made the change. |
08-22-2019, 12:55 PM | #6 |
08-22-2019, 01:22 PM | #7 | |
08-22-2019, 01:29 PM | #8 | |
Arid refers to an area with little rainfall and doesn't describe temperature either high or low. The reference to Mexico may be an attempt to mean the maroon fenders would apply to hot climates? Much of Mexico including many major cites are between 6-8,000' and have a quite temperate climate due to the elevation. In any case, I can't see any science or other reasons to paint fenders maroon for either hot or arid climate markets.
All steel from pedal to wheel Last edited by Dick Steinkamp; 08-22-2019 at 01:48 PM. |
08-22-2019, 01:43 PM | #9 |
08-24-2019, 09:41 AM | #10 | |
Y-Blockhead, I fully agree. I just ignore these types of responses.
[email protected] - email contact https://aafords.com Ford Model AA Truck Club @ aafords.com |
08-24-2019, 10:33 AM | #11 | |
Correct! Sorry. Bit of wry humor there. Joe K
Shudda kept the horse. |
08-24-2019, 12:04 PM | #12 | |
That is pretty much the same reason why Fred Morse (https://www.fordbarn.com/forum/member.php?u=699) was banned before, ...and why he just re-registered under the new FM username. . . |
08-25-2019, 11:31 AM | #13 |
Hi Jon,
If it's Scott's car, his Tudor was built in Canada. Fenders the fenders, running board shields and radiator apron were originally black, but I like Scott's car the way it is.
Bob Bidonde |
08-25-2019, 12:02 PM | #14 |
Is this a pull my finger scenario?
08-25-2019, 12:22 PM | #15 |
The dip conveyor at Long Beach assembly,heading into the oven..amazing they just dip it and it comes out good..on the other hand maybe it didn't come out so good..
08-25-2019, 12:54 PM | #16 |
08-25-2019, 01:58 PM | #17 |
08-25-2019, 02:19 PM | #18 |
08-26-2019, 02:31 PM | #19 | |
Why sure, ...why wouldn't it? From my experiences in fine point (-both showing and adjudicating) it is unauthentic materials or incorrect parts used that usually causes the biggest scoring deductions. The second biggest area that many get a deduction for is over-restoration. In the case of the fender finish, the fenders were originally new metal that was stamped. There was a department that 'tuned-up' the metal if there were any flaws created in the stamping process such as a deep scratch or maybe if the fender was bumped as it was removed during handling. So you had new metal without pits or dents that was wiped down and dipped into a thick Black alkyd enamel with a bonderizer and then removed for drying in a steam oven. The fenders were free of trash and orange peel because of the dipping process. When the fender had dried, it was lightly sanded with sandpaper and then re-dipped into another vat of Black enamel. Because of the way the fender was dipped and hung, all excess paint flowed off the edge and the finish was super slick. Today the finish must color-sanded and buffed to replicate the original finish. The same with wheels and other parts. So yes, a Model-A fresh off the assembly line should score well. . |
08-26-2019, 04:21 PM | #20 |
The only in black is true for US cars, but down here in Australia, Model A's came with different coloured mudguards and wheels. One combination was tan body with brown mudguards and wheels, other combinations were available. One of my earlier posts afew years ago has the full list of available combinations.
