Old 10-16-2020, 11:09 AM   #1
AL in NY
AL in NY's Avatar
Default 35 Ford Hubcaps
I recently installed 35 Ford wheels on my 30 CCPU. I purchased new hubcaps from Snyder's that fit reallllllly well. The problem is these hubcaps are extremely hard to remove. Is there a special tool that Ford sold to remove these hubcaps without marring the paint/powder coat finish on the wheels?
AL in NY
AL in NY is offline   Reply With Quote
Old 10-16-2020, 01:15 PM   #2
Sunnybrook Farm
Sunnybrook Farm's Avatar
Default Re: 35 Ford Hubcaps
Wood wedge or one of those plastic (really strong) ones that Stihl sells for driving in a tree. Just something to get it started to where you can grab it.
Sunnybrook Farm is offline   Reply With Quote
Old 10-17-2020, 08:09 AM   #3
Pat/Ohio
Pat/Ohio's Avatar
I use the yellow plastic bondo spreaders you pick up at swap meets etc. Place the thin edge between the hubcap and wheel then use a flat screwdriver to pry against the yellow spreader. Have done this for years with no paint chips etc.
Pat
Pat/Ohio is offline   Reply With Quote
Old 10-17-2020, 08:21 AM   #4
30 Closed Cab PU
Pat
Nice method Pat, kinda like using wide putty knives to protect drywall/trim when prying kick boards/mop boards/trim off drywall. Going to try this instead of my method above, next time.
Old 10-17-2020, 01:58 PM   #5
1931 flamingo
1931 flamingo's Avatar
Harbor Freight has a set of plastic tools, so I'm told.
Paul in CT
Old 10-17-2020, 02:50 PM   #6
CA Victoria
CA Victoria's Avatar
HF sell a hard plastic tool, this one came from a Swapmeet it is 1” wide w/a double taper and a sharp edge to get into the seam.
Works well-
File Type: jpg 13CD3E0A-AF8E-4B61-8B4B-5E8202371A35.jpg (46.9 KB, 23 views)
File Type: jpg 6C1AF65F-5AB3-4C8D-8C94-887DC3C25FA7.jpg (27.2 KB, 21 views)
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 10-17-2020, 03:43 PM   #7
McMimmcs
McMimmcs's Avatar
Pat
A well tested procedure.
Old 10-17-2020, 05:58 PM   #8
AL in NY
AL in NY's Avatar
Looks like I'll take a ride the HF and pick up these plastic wedge tools.
AL in NY
Old 10-17-2020, 06:10 PM   #9
McMimmcs
McMimmcs's Avatar
And while you’re at it a big thanks to Pat in Ohio for a great tip !
Old 10-17-2020, 11:06 PM   #10
daveymc29
daveymc29's Avatar
I use a 3 or 6 inch putty knife and a screw drive, putty knife in place between tire and rim, a little pull outward and if the cap doesn't move right away I then shove the screw driver between the cap and putty knife. Haven't hurt my powder coating in twenty years. Rubber hammer to refit.
daveymc29 is offline   Reply With Quote
