09-29-2020, 01:29 PM | #1 |
dimmer switch 40-41
Arrrgh, I have tried 2 different aftermarket dimmer switches, each seem to not work or fail after a short amount of use. Anyone had good luck with one that they would recommend?
thanks in advance. |
09-29-2020, 02:25 PM | #2 |
Re: dimmer switch 40-41
If you mean the head light dimmer switch this one looks promising as it was made back in the day as a replacement.
https://www.ebay.com/itm/1938-1947-F...UAAOSwHMJYCVyZ Plus, there are a few for sale in the Swap Section. Just type in dimmer switch. Last edited by 19Fordy; 09-29-2020 at 02:31 PM. |
09-29-2020, 03:16 PM | #3 |
Or this one on eBay a lot cheaper...
Item ID: 124357131864
09-29-2020, 07:07 PM | #4 |
Go here instead. Jack E/NJ
09-30-2020, 08:23 AM | #5 |
I believe in my 40 the switch is in the correct position BUT there's no way I can get my 10 1/2's on to it..................
Paul in CT |
09-30-2020, 08:45 AM | #6 |
09-30-2020, 09:56 AM | #7 |
09-30-2020, 11:07 AM | #8 |
OK, now I get it. Thanks.
10-02-2020, 09:58 AM | #9 |
Thank you for your help guys. Hopefully this solves the problem once and for all.
10-02-2020, 01:13 PM | #10 |
For the record regarding location of the dimmer switch hole:
The dimmer switch on my early model year '41 is lower on the floorboard; slightly below the clutch pedal hole. When I bought a replacement floorboard advertised to fit '41 to '48, the unit I received had the dimmer hole much higher up on the floorboard. I recall that from the '48 I owned 60 years ago as being correct position for that car. The wiring for the dimmer on my '41 would not reach far enough, so I cut a hole lower in the floorboard. That location is easier to reach but also subject to inadvertent activation. |
