Old 09-20-2020, 08:07 AM   #1
Lincoln29
Default Rear Main seal
I am rebuilding a 1936 LB motor and the rear main cap is the correct one but the slinger that the book shows doesn't fit in the cap. The slinger in the block works fine, not sure what to do about the cap. I have attached a couple of pictures. Please advise. Thanks, Jerry
Lincoln29 is offline   Reply With Quote
Old 09-20-2020, 09:42 AM   #2
JSeery
JSeery's Avatar
Default Re: Rear Main seal
VanPelt sells them, I would think he could help you out.
http://www.vanpeltsales.com/FH_web/e...prices-pg2.htm
Old 09-20-2020, 01:56 PM   #3
Brian
Brian's Avatar
That cap is fitted as it is. The die cast insert 'that the book shows' was introduced sometime through the 1937 year.
Old 09-20-2020, 03:45 PM   #4
Ronnieroadster
Ronnieroadster's Avatar
Your rear main bearing cap is not made for any of the insert type seal mounts. Your original crankshaft has two flanges at the rear one if for the beading thrust surface and the second is a slinger was designed to hopefully keep oil in the pan. In effect there's no separate rear rope seals in the early engines with the second flange.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder and Driver of the First Ford Flathead bodied roadster to run 200 MPH Record run July 13, 2018 LTA timing association 200.921 from a standing start in one and a half miles burning gasoline.
Old 09-20-2020, 08:07 PM   #5
Lincoln29
Thanks guys, you have been a lot of knowledge.
Jerry
Old 09-21-2020, 09:17 AM   #6
Zeke3
Zeke3's Avatar
Jerry, thanks for posting this question, my 37 21 stud engine has the same rear main cap as yours. I also purchased the insert for it, but haven't even unwrapped it. Guess I can add it to the swap meet pile since I don't need it.
Zeke3 is offline   Reply With Quote
