Old 08-25-2020, 04:26 PM   #1
gcenb1
Question Distributor lower shaft removal
Still cannot get lower shaft out...have tried everything I can think of, but no luck. It turns with no problem cranking the engine, but just will not lift out, no matter what I try. Am I the only person who has ever run into this?
gcenb1 is offline   Reply With Quote
Old 08-25-2020, 04:51 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Distributor lower shaft removal
What seems to be the problem ? Does it seem to be rusted in place ? You're not able to get it to 'wobble' around ?
Usually a tap on the head and a twist, then pull it up with something like snap ring pliers.
Old 08-25-2020, 05:10 PM   #3
gcenb1
It does seem like it's stuck to the oil pump gear. Can't imagine why it won't lift out. It rotates with no problem, but won't lift an iota.
Old 08-25-2020, 05:22 PM   #4
chrs1961815
chrs1961815's Avatar
Older reproductions were sometimes a poor fit, too tight or too loose. It could also be that the shafts are rusted together. Have you tried grabbing it with something? Could try a magnet as well.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 08-25-2020, 05:51 PM   #5
Bob C
I had an older reproduction one that the tang on the drive gear and the
slot in the lower shaft were not a match and were STUCK. I had to make a collet type puller to get the lower shaft out.
Old 08-25-2020, 06:05 PM   #6
dpson
dpson's Avatar
Oh wow, that's pretty clever. Nice work!
dpson is offline   Reply With Quote
Old 08-25-2020, 09:46 PM   #7
PalAl
PalAl's Avatar
Endless talent in this hobby, great that you all share.
Nice job Bob thanks for sharing.
I once fashioned a coat hanger, with my own two hands and my own design, to help unlock my car door....LOL
PalAl is offline   Reply With Quote
Old 08-26-2020, 05:51 AM   #8
Patrick L.
Patrick L.'s Avatar
Hmmm. interesting. Nice.
You never know what you're gonna find with these critters.
Old 08-26-2020, 07:02 AM   #9
Ted Duke
Smile Re: Distributor lower shaft removal
PalAl,
Oh my, that brings back funny memories. Funny for other people then and funny for me 60 yrs later. I did that on the Sunday morning the day after my marriage to my wonderful wife. We went to Mass in Williamsburg, Virginia and I had to "borrow" a coat hangar from the priest afterwards to get in my 1961 Chevrolet BelAir hardtop.
Ted Duke is offline   Reply With Quote
Old 08-26-2020, 08:07 AM   #10
rocket1
Gcenb1 put your location in your avatar might be someone near you that can help,send a pm to the barner that made the tool possibly you can borrow it.
rocket1 is offline   Reply With Quote
Old 08-26-2020, 04:33 PM   #11
PalAl
PalAl's Avatar
Originally Posted by Ted Duke View Post
PalAl,
Now that's funny, bet you were red faced that Sunday morning
Old 08-26-2020, 05:16 PM   #12
1crosscut
1crosscut's Avatar
Locked the keys in my pickup many moons ago in front of the police station here in Lincoln Nebraska. Used a coat hanger to get it unlocked. Took me about a half an hour to do it. Had at least 15 officers walk by me. Not one of them checked to make sure I was breaking into my own truck. Safest place to steal a vehicle I guess.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 08-26-2020, 06:22 PM   #13
Smooth_One
Smooth_One's Avatar
Take the oil pump out as a last resort?
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 08-26-2020, 09:48 PM   #14
PalAl
PalAl's Avatar
No one wanted to do the paper work.............
Old 08-27-2020, 12:11 AM   #15
IndyA
Had the same problem. Cut a 2x4 about the height from the floor to the middle of the valve compartment - took a vice grip plier, laid the back of the plier on the top of the standing 2x4 (as in a fulcrum arrangement); clamped the jaws on the distributor shaft and whacked downward on the back end of the vice grip... out she came !!!!!
IndyA is offline   Reply With Quote
Old 08-27-2020, 08:07 AM   #16
Big hammer
When I pulled my distributor it had the one piece shat, when I reinstalled the distributor I went with the origins two piece shaft.
The shaft that your going after, how far down from the surface of the head is the end? 1to 2 inches or 6to7 inches?
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 08-29-2020, 07:53 PM   #17
gcenb1
Well, finally got it out...used a vice grip, and between wiggling it side to side, and tapping up on the vice grip, finally was able to very slowly work it up....was totally rusted at top of shaft! Thanks for all the advice and suggestions...very much appreciated.
