Old 04-25-2021, 07:47 AM   #1
bobsmanstuff
bobsmanstuff's Avatar
Default visor
Hey Guys, I was able to find a exterior windshield visor for my 53 customline. Wondered if any one had experience putting one on. What size and length screws to use. Two on each end and one on the top center. Thanks for any help.
bobsmanstuff is offline   Reply With Quote
Old 04-25-2021, 08:35 AM   #2
41ford1
41ford1's Avatar
Default Re: visor
Check this thread: https://www.fordbarn.com/forum/showthread.php?t=203088
The screws are #12 X 1 1/2" on the sides. I believe they are the same on the center bracket. I have not removed that to check.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 04-25-2021, 10:01 AM   #3
bobsmanstuff
Default Re: visor
Thanks
Old 04-25-2021, 10:02 AM   #4
RalphG
RalphG's Avatar
Default Re: visor
Mine on the 52 Merc has small screws each end on the drip rail and very large through the roof on the centre bracket.
Edit. the outer screws were not on the drip rail but instead were attached to the front corner post itself.
RalphG is offline   Reply With Quote
Old 04-26-2021, 09:33 AM   #5
47Monarch
47Monarch's Avatar
Default Re: visor
I had one on a 48 pontiac center had a bracket that bolted to center widow frame ends fit in drip rail and small sheet metal screws
47Monarch is offline   Reply With Quote
