Old 08-29-2020, 06:46 AM   #1
Daba
Default Mechanical fuel pump
Mechanical fuel pump.
I recently purchased another 31 Model A Three window four-door, it came with a model B motor with a mechanical fuel pump. My question is should I continue using the mechanical fuel pump or use the gravity feed like most of Model A’s not sure if it makes a difference or not. I was told the fuel pump is valuable and should put a cover on the motor and try to sell it?? I guess the real question is will it run any different with or without a mechanical fuel pump thanks in advance for your help. Daba
Daba is offline   Reply With Quote
Old 08-29-2020, 07:44 AM   #2
emf
emf's Avatar
Default Re: Mechanical fuel pump
If you are running an updraft carburetor, nix the pump. If a downdraft, you'll need it. If updraft, keep it for now, in case you change your mind...
Frank
emf is offline   Reply With Quote
Old 08-29-2020, 11:47 AM   #3
Jim Brierley
Amen!
Jim Brierley is offline   Reply With Quote
Old 08-29-2020, 08:26 PM   #4
700rpm
700rpm's Avatar
Gravity never stops working and never breaks down.
Ray Horton, Portland, OR
Old 08-29-2020, 08:36 PM   #5
Jack Shaft
Frank
My wife calls me a hoarder for that..
Jack Shaft is offline   Reply With Quote
