Old 05-19-2020, 02:07 PM   #1
AnthonyG
AnthonyG's Avatar
Default 1940 pickup carpeting?
Who can I get a precut & hemmed carpeting for a ‘40 Ford 1/2 ton cab? Thought it’d b easy 2 find? Not!
Nomad
AnthonyG is offline   Reply With Quote
Old 05-19-2020, 02:15 PM   #2
JSeery
JSeery's Avatar
Default Re: 1940 pickup carpeting?
Partly because it is not an original item.
Old 05-19-2020, 02:48 PM   #3
AnthonyG
AnthonyG's Avatar
Mine came w a nicely made w hems & cut perfect. Truck had a brake fluid leak Probly in storage that got left a long time & destroyed the carpeting. Looked like a bought item but starting to think interior shop Custom made.
Nomad
Old 05-19-2020, 02:57 PM   #4
hotrodart
hotrodart's Avatar
Try a convertible top shop. I had one do an entire interior, plus the trunk on one of my hot rods. The cost was a fraction of any custom upholstery shop and the workmanship was very high quality.
hotrodart is offline   Reply With Quote
Old 05-19-2020, 04:18 PM   #5
ford38v8
ford38v8's Avatar
Back in the day, it was tuck & roll from Tiajuana
Then ever after, fish out stale french fries from between the tucks!
...And loose change for gas
Alan
Old 05-19-2020, 04:27 PM   #6
41ford1
41ford1's Avatar
How did a master cylinder leak destroy the carpet? The stock placement for it is under the floor. BTW the stock floor covering is a rubber mat.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 05-19-2020, 07:38 PM   #7
AnthonyG
AnthonyG's Avatar
Not stock, firewall mounted dual Master cylinder.
Nomad
Old 05-19-2020, 08:27 PM   #8
CaliforniaBorn36
CaliforniaBorn36's Avatar
Bought inexpensive black loop carpet at Home Depot and cut my own. doesn't have binding, but very easy to cut to shape. There are some products you can find online to bind the edges. Otherwise custom from auto upholstery shop.
Not original, so it all depends on your budget.
CaliforniaBorn36 is offline   Reply With Quote
Old 05-20-2020, 08:05 AM   #9
1931 flamingo
1931 flamingo's Avatar
When I had my Model A I picked up a rug at Home Depot that almost matched original carpet, made patters (paper) and cut to fit. Picked up some trim material at JoAnn Fabrics and used a glue gun to bind to carpet.. Came out quite nice vs buying new from one of the vendors. FWIW
Paul in CT
Old 05-20-2020, 08:40 AM   #10
TJ
TJ's Avatar
I've often cut my own carpet(yes Home Depot has some good looking indoor/outdoor carpet).I then take it to an upholstery shop and have the binding installed.
Old 05-20-2020, 10:49 AM   #11
38bill
38bill's Avatar
Check your local Yellow Pages (do they still even have them?) or contact some carpet stores for a person that does carpet binding. Should be easy to find one.
38bill is offline   Reply With Quote
Old 05-20-2020, 03:03 PM   #12
TomT/Williamsburg
TomT/Williamsburg's Avatar
For my wife’s 40 pickup I am building I bought a $20 piece of medium grey carpet which is plenty for the firewall and floor. I will the get some matching or contrasting vinyl from JoAnns, cut long 2” strips, and bind it myself. I have done this several times with great success .....
TomT/Williamsburg is offline   Reply With Quote
Old 05-21-2020, 11:35 AM   #13
CaliforniaBorn36
This link might help if you decide to do it yourself:
https://www.bondproducts.com/instabi...UaArIOEALw_wcB
Old 05-21-2020, 03:29 PM   #14
TJ
TJ's Avatar
Thanks for the link. looks like some good products.
Old 05-24-2020, 08:33 AM   #15
AnthonyG
AnthonyG's Avatar
I’ll Probly take existing carpet that has bound Edges & fit nicely to an interior shop & let them use as a pattern 2 make a new 1.
Nomad
