Old 06-03-2016, 07:02 PM   #1
kurtis v-8-60
Default harmon collils
Need Harmon Collins distributor cap for magneto model # 101
kurtis v-8-60 is offline   Reply With Quote
Old 06-04-2016, 05:29 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: harmon collils
Send a PM to DzusFast here on fordbarn.com he has rotors or you can get them on ebay search Harman Collins. It is possible to convert the mag to a common Ford distributor rotor.
Old 06-04-2016, 06:32 AM   #3
KiWinUS
KiWinUS's Avatar
If it is just the cap you need , any crab cap will work & not break you rotor (be sure & check as you install) on a H&C Magneto.
The same can not be said for the H&C Dual coil distributor.
Dzusfast has the Distributor rotors!.
If you just want the original smoothe inside cap , PM me I have some NOS caps.
Cheers
Tony
Old 06-04-2016, 11:52 AM   #4
kurtis v-8-60
Tony: I do need the smooth inside cap. Let me know how we do this $$$ You guys at the barn are always so much help.
Thanks Harold
Old 06-04-2016, 04:10 PM   #5
Terry,OH
Terry,OH's Avatar
Harold: Left click on KiwinUS name above. Then on the drop down menu click on send a private message.
