Old 03-10-2020, 07:42 AM   #1
Bustingear
Default Carburetor ID Help
Got these two at a swap meet in a box of 94's and need help pinning them down.
The gold tint one is a Carter and the Aluminum cast one is a Detroit Lubricator. Would like some help in understanding what years , brands and models they were used in and anything on their value which I know may be subjective. Thanks!
Bustingear is offline   Reply With Quote
Old 03-10-2020, 09:56 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: Carburetor ID Help
Here´s your detroit on an intake...
Thoose early 1 barrels aren´t to fun to tune...think most driving the cars got rid of them and went with a later intake.
Old 03-10-2020, 11:26 AM   #3
scicala
scicala's Avatar
The Carter one barrel is a YF model. Don't know the application, but it appears to have a brass tag on it with the carter part number. If you tell us that number, it's pretty easy to find the application. The other carb (Detroit Lubricator) appears to be the type used on '32 and '33 Ford V8's. "Charlie ny" on this forum should be able to confirm that or not.
Sal
scicala is offline   Reply With Quote
Old 03-10-2020, 12:44 PM   #4
Bustingear
Thanks did some more research. the Detroit info is correct above and the carter is 1941-1953 Willys Jeep Military issue
Old 03-10-2020, 12:54 PM   #5
deuce lover
deuce lover's Avatar
The Detroit Lubricator is 1933 Ford and not worth much.Even at $25 on EBAY they sit.
