Old 07-19-2020, 04:20 AM   #1
Paul Bennett
Default WorryWart
My dash clock (50 Merc - 12v) has been refurbished and when I reinstalled it I noted the clock solenoid clicks every 5-6 minutes to pump up the wind mechanism. I formerly thought the intervals would be more like 30 minutes or an hour.
It would be nice to know how much energy is consumed each time it clicks to calculate how much it depletes the battery but that's not my question.
But I can worry that the clock could eventually drain the battery, drip drip drip.
Has anyone found the need to disconnect the clock if the car isn't run every 3months? 6months?
Or dust I worry for naught?
Paul Bennett is offline   Reply With Quote
Old 07-19-2020, 04:59 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: WorryWart
It only uses battery energy for a split second to wind it.
I never had a problem with it for as long as 3 months.
Old 07-19-2020, 08:17 AM   #3
51504bat
51504bat's Avatar
If you're worried hook up a battery maintainer.
Old 07-19-2020, 09:07 AM   #4
rotorwrench
rotorwrench's Avatar
When I was in the Army, I learned the proper interval for a maintenance operational check or MOC. A motor vehicle, whether it's a wheeled vehicle, a tracked vehicle, a boat, or an aircraft, should be run up every 14-days. This is considered maximum time out of service or the vehicle has to be prepped for either short term or long term storage.
If a person does this, the systems will remain usable and in good condition for a lot longer than those that set too long. Fuel doesn't last very long now days so it's very important to keep it fresh.
Old 07-19-2020, 12:09 PM   #5
Ben38
Ben38's Avatar
How long did you let them run?
Ben38 is offline   Reply With Quote
Old 07-19-2020, 12:55 PM   #6
Jersey Devil
Jersey Devil's Avatar
51504 bat‘s reply is the best option. Use a battery tender for idle periods longer than 2/3 months. Also you could always remove the fuse temporarily.
Some recommend a 1amp fuse in the radio. That way as the voltage drops during storage the current flow to the radio will increase and eventually cause the fuse to blow. That takes the load off of what’s left of the battery.
Over the winter I use the battery tender and also remove the fuse to reduce ware on the points in the clock.
Tom
Jersey Devil is offline   Reply With Quote
Old 07-19-2020, 06:45 PM   #7
51 MERC-CT
51 MERC-CT's Avatar
Tom
To me it makes more sense to disconnect the clock to reduce arcing buildup on the clock points than to disconnect it to save the battery.
Old 07-19-2020, 07:13 PM   #8
50fordcoupeman
50fordcoupeman's Avatar
Hi Paul..........why not use a battery disconnect and get rid of all electrical worries when the car is not in use? A friend of mine had a battery tender go south on him on burned up his vehicle. Sh** happens.
50fordcoupeman is offline   Reply With Quote
Old 07-19-2020, 01:04 PM   #9
5851a
Considering apples to oranges, I've had wall clocks operate for 2 years on a double A battery. Don't think you have much to worry about. 5 to 6 minutes sounds about right. 51 Merc is correct, it's just a split second.
5851a is offline   Reply With Quote
Old 07-23-2020, 12:37 AM   #10
Paul Bennett
Once upon a time I had the ability to use a battery maintainer. Battery maintainers require a house or garage. OTOH, apartment living negates having power where the car will be parked. Guess it means starting the car every 14 days and I'm anxious to hear an good answer about how long to run the engine.
And I must reread the post about connecting the clock to the battery with a fuse which blows under some conditions. Huh? As I said, a reread is in order.
