Old 03-12-2020, 01:14 PM   #1
Ken Arms
Ken Arms's Avatar
Default Engine oil
What's the opinion here for oil? I have a rebuilt 59ab with break-in oil in it presently, I think it has zink in it. Now ready for first oil change, I want to use full synthetic and ad a zink additive to it. Opinions? Ken
Ken Arms is offline   Reply With Quote
Old 03-12-2020, 01:20 PM   #2
flatjack9
flatjack9's Avatar
Default Re: Engine oil
Pick up any good engine oil. There is still enough zinc in them for a flathead. I use 10W 30 Valvoline.
Old 03-12-2020, 01:30 PM   #3
philipswanson
Mobil I 10W 30 would be fine. I use straight 30W here in SoCa. Any good synthetic sold at Walmart. Forget Zinc in a flathead. Very low valve spring pressures.
philipswanson is offline   Reply With Quote
Old 03-12-2020, 01:40 PM   #4
V8 Bob
V8 Bob's Avatar
IMO, if you need to use an additive, you're using the wrong oil. Best to pick an oil that meets all your requirements. Too much ZDDP can cause more damage than not enough.
I agree with jack on using regular Valvoline on all my flat tappet engines, but do use Valvoline VR-1 10W30 non-synthetic on my roadster's flathead because of a pretty radical cam, although probably overkill.
V8 Bob is offline   Reply With Quote
Old 03-12-2020, 02:08 PM   #5
dbtenner
dbtenner's Avatar
Agreed with the above statement. Most oils contain enough zinc that ZDDP additive should not be used.
I use SAE straight 40 weight Shell Rotella for my 34’ Roadster. Never an issue. As I have always been told oil passages in these flatheads are large for straight and not to use a synthetic. I’m sure someone can explain why synthetic has disadvantages.
That’s what I’ve always been told and sticking with it.
dbtenner is offline   Reply With Quote
Old 03-12-2020, 02:21 PM   #6
flatheadmurre
flatheadmurre's Avatar
Don´t be to quick with changing to synthetic oil...give it a good work out on a regular quality oil first.
If your engine is not completely done with the break-in...synthetic additives doesn´t do you any good...
Old 03-12-2020, 03:56 PM   #7
Fordestes
I agree with flatheadmurre, I go a bout 10k miles and then switch to synthetic, every gas engine I know of that has used Mobil 1 has ran over 200k miles before a rebuild and has shown less wear than any gas engine with the same miles using Dinosaur oil. I also take into account whether the operating conditions are in a clean environment , sometimes oil can be contaminated by dirt or moisture which means more frequent oil changes are necessary, more frequent changes from the economic standpoint makes synthetic less cost effective versus Dinosaur oil. Just my opinion.
Fordestes is offline   Reply With Quote
Old 03-12-2020, 04:36 PM   #8
tubman
tubman's Avatar
I but anything the local "Dollar General" has on sale for less than $3 a quart as long as it has an "API" seal on it. 10-30. 10-40, whatever; just no non-detergent.
tubman is online now   Reply With Quote
Old 03-12-2020, 08:03 PM   #9
lotsagas4u
10W 30 Valvoline ZR1
lotsagas4u is offline   Reply With Quote
Old 03-12-2020, 08:50 PM   #10
VeryTangled
VeryTangled's Avatar
I've seen local grocery store brands have the API starburst. That works.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 03-12-2020, 09:11 PM   #11
Ole Don
Ole Don's Avatar
Search Bobtheoilman.
Ole Don is offline   Reply With Quote
