Old 10-11-2015, 02:03 PM   #1
Ian in Mississauga
Default Gas with stabilizer
How long can I use premium gas(no ethanol) that's had stabilizer added?
Ian in Mississauga is offline   Reply With Quote
Old 10-11-2015, 02:23 PM   #2
Brentwood Bob
Default Re: Gas with stabilizer
stabilizer, i believe. mentions storage. try the fuel, if necessary dilute with new gas.
bob
Brentwood Bob is offline   Reply With Quote
Old 10-11-2015, 05:12 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I "think" that during storage, it helps to keep the tank FULL??
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-11-2015, 05:15 PM   #4
ed thibodeau
I have had it work in my 8N tractor that was stored for over a year in an unheated shed . It started right up and ran fine. I run a zenith in my tractor.
ed thibodeau is offline   Reply With Quote
Old 10-11-2015, 06:55 PM   #5
1crosscut
1crosscut's Avatar
Like Bill said... full tank for storage. If not full I would make it totally empty.
I think that fuel without ethanol will last in storage a surprisingly long time as long as the tank is full. I wouldn't bother with adding a stabilizer just for one winter season with a full tank that does not have ethanol.
As far as using a premium grade gasoline it is not necessary. The higher octane premium gasoline is only needed with a high compression engine to prevent pre-ignition (knocking). Your A does not need it nor does it probably like it.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-11-2015, 07:24 PM   #6
Ian in Mississauga
Dave, thanks for responding. I know hi octane is wasted on a Model A, but the only alcohol-free gas around here is Shell premium.
Ian
Old 10-11-2015, 10:34 PM   #7
w.michael
w.michael's Avatar
I stored a modern car for 2 1/2 years with a full tank of premium ethanol-added gasoline and a bottle of Sta-Bil, and it was still good when taken out of storage. Ran fine, and I burned almost all of that tankful before I added fresh fuel.
W. Michael
w.michael is offline   Reply With Quote
Old 10-12-2015, 08:47 AM   #8
BILL WILLIAMSON
W. Michael
Michael,
My Dodge Dakota sat with a full tank for a year & a half & it still smelled fresh. Once a week it was run for a short while, to keep the battery up & to keep the fuel pump WHIZZING.
The closed venting system probably helped. I "wonder" if it would help on a Model A, to put plastic wrap on the neck, then put the cap on, to help keep moisture out???
Bill W.
Old 10-12-2015, 03:26 PM   #9
ian Simpson
I use only ethanol free Shell Premium in the collector cars. Each is topped right up before storage and no stabiliser added. Did use stabiliser one year a while back, and had a heck of a job starting them all up. Even the lawnmower gave trouble.
ian Simpson is offline   Reply With Quote
Old 10-12-2015, 03:34 PM   #10
Patrick L.
Patrick L.'s Avatar
Non-ethanal fuel is supposed to last for at least a year.
I've had Stabil go bad, it doesn't last long. I'm a Sea-Foam guy.
Old 10-12-2015, 03:42 PM   #11
Mitch//pa
Originally Posted by BILL WILLIAMSON View Post
Michael,
Bill W.
your very lucky pop, get that crap out of there even if you have to let it idle in front of the house for a week
Old 10-12-2015, 04:30 PM   #12
BILL WILLIAMSON
Thanks for your concern, My Man, I "rented" it to Perla for a week & she burned it up!
Dad
