08-07-2010, 07:51 AM | #1 |
Adapting '39Ford transmission to '53 Flathead
Hi all, I own a 1940 Ford pickup and recently got a good running 53 flathead engine I want to install in the truck. I understand I may need some type of bell housing adapter to have the newer engine accept the old 39 top loader? Is that a Ford Part or an OEM adapter of some type? Will I need to change anything else besides the bell housing? Will the motor mounts work?
Thanks in advance! Fat Fender Last edited by FatFender; 08-07-2010 at 08:19 AM. |
08-07-2010, 08:00 AM | #2 |
Re: Adapting '39Ford transmission to '53 Flathead
A truck or Merc bell housing and water pumps should be the ticket for getting that 8ba engine in your '40 PU.
08-07-2010, 08:01 AM | #3 |
You have two choices to make the trans fit. One is the bell housing & starter plate from any 1949-50/51 mercury. The other is the bell housing & starter plate from any 1948-51 F-1 truck. The Merc bell was a heavy stamped steel housing. The F-1 bell was a cast iron piece.
The trans will need to have the 1940-48 type clutch release shaft (with the flat "tab" on the left end for the clutch equalizer shaft that goes over to the frame on the 1940-48 vehicles. The trans should also have the 1937-41 style rear bearing retainer which has the 10" bolt hole spacing.
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
08-07-2010, 08:10 AM | #4 |
your also going to need truck water pumps 8RT i believe is the number,also a fan setup because the stock 53 fan will interfear with upper rad hoses.
08-07-2010, 08:27 AM | #5 |
If you can't find a 49 thru early 51 Mercury Borg & Beck clutch with flywheel you can use any 8BA flywheel and have it drilled for the early Long type clutch pressure plate & disk used with the 1 3/8 trans input spline.
Kerby |
11-11-2010, 12:40 AM | #6 |
Give me a call if interested. Steve (760) 486-5950 |
