05-19-2023, 06:06 PM | #21 |
Re: hood removal
I rigged a ceiling mounted bicycle lift to raise the hood by a single person... If you can send me your e-mail and I'll send [email protected]
05-20-2023, 09:41 AM | #22 |
Re: hood removal
ask a neighbor for help.............
05-20-2023, 06:55 PM | #23 |
Re: hood removal
I did what MCHinson and Bruce recommended. Knowing my coordination is not what it used to be I removed the front bumper first. 2 bolts and thats off. It all went smoothly.
05-21-2023, 09:44 AM | #24 | |
Re: hood removal
BTW, anyone know the weight of a complete hood assembly?
05-21-2023, 06:02 PM | #25 |
Re: hood removal
30 - 31 hood tops =7 lbs each and sides are also about 7lbs each so 28 lbs give or take
05-22-2023, 04:58 PM | #26 |
Re: hood removal
05-22-2023, 05:34 PM | #27 |
Re: hood removal
Lifting it off is no where near half of the problem. Putting it back is way more difficult. I think you'd do well to stretch your mind and see if you can find someone to help. A friend, relative, club member, even the kid down the road.
05-24-2023, 06:54 AM | #28 |
Re: hood removal
The early Model T's had aluminum hoods which are really easy to lift off. The hood on the early Model T can be lifted off without removing any fasteners. Very handy for working on the engine.
Are aluminum hoods available for Model A's?
05-24-2023, 07:35 AM | #29 |
Re: hood removal
Two HF purple lifting straps (6'-5") and a HF 1 1/2 ton engine hoist make it easy. The straps fit perfectly.
05-26-2023, 07:03 PM | #30 |
Re: hood removal
A couple of ropes over the garage rafters.Towels in between. Pull each side up slowly. That's how I got mine off 2 years ago.
