05-18-2023, 08:33 PM | #1 |
Rough Idle When Pointed Uphill
Hi all. I'm scratching my head a little with this one. I have a good Zenith 2 on my car that runs great down the road with good response and power. The idle get's a little odd under certain circumstances. It idles great when the car is on a flat surface or if the car is pointed downhill, but it idles rough when the car is pointed uphill (i.e. on my driveway with the front of the car point uphill). I'm a little confused by this one. Thoughts??
Thanks in advance! Matt
1929 Briggs Fordor 165B 1930 Deluxe Coupe 1966 Mustang 2015 Ford Focus ST |
05-18-2023, 09:30 PM | #2 |
Re: Rough Idle When Pointed Uphill
Must be the float setting.
05-18-2023, 09:53 PM | #3 |
That would make sense, except the gas would slosh to the back of the bowl where the jets/passages are, right? Not starving the carb of fuel?
05-18-2023, 10:05 PM | #4 |
Not enough fuel flowing from the tank to the carb when you ask it to over come gravity by pointing the flow path up hill.
05-18-2023, 10:59 PM | #5 |
There would be plenty of gravity in a model A, but too little or too much gas can cause rough idling.
05-19-2023, 06:49 AM | #6 |
05-19-2023, 08:16 AM | #7 |
How steep? And did you tighten the GAV a bit?
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
05-19-2023, 08:40 AM | #8 |
I tend to agree with bruceincam regarding fuel flow from the tank. Have you tried testing in uphill position with a full tank? If it improves the smoothness at idle then you might have a restriction in your fuel tank. A change in head pressure might affect fuel flow when in the uphill position with a low level of fuel.
05-19-2023, 10:36 AM | #9 |
You'd think it wouldn't run well down the road if there was a fuel flow issue, but it runs great down the road with good power.
05-19-2023, 10:37 AM | #10 |
Typical driveway steepness of maybe 4-5% grade, so not that steep.
05-19-2023, 10:38 AM | #11 | |
It has 3/4 of a tank right now. It runs great down the road with good power, which you wouldn't expect if there was a fuel flow issue.
05-19-2023, 12:19 PM | #12 |
Might change the float. A worn spot above the float valve??
05-19-2023, 01:57 PM | #13 |
That's a thought. I've got a bunch of floats, so I'll try that. Thanks!
