05-02-2023, 09:37 AM | #81 |
Re: MMO in the Gas
I thought ZDDP was added to the oil. Lead was banned from fuels. I don't believe zinc was ever added to gasoline.
The Master Cylinder Enjoying life at the beach in SoCal... |
05-15-2023, 09:32 PM | #82 |
Re: MMO in the Gas
I was watching a video that Paul Shinn had about cleaning a gas tank and he said a little MMO in the gas helps prevent rust.....sounds logical to me
05-16-2023, 06:57 AM | #83 |
Re: MMO in the Gas
I see plenty of gas tanks that come to me for restoration after folks have tried all of these remedies that seem to counter that logic. One being MMO! I've even had one come in where they read/watched/whatever somewhere how some authority recommended using POR15 on the inside of the gas tank to cure the rust problem.
05-16-2023, 08:10 AM | #84 |
Re: MMO in the Gas
If you changed the oil and are driving it more, that could explain what happened to your car. Without performing controlled tests, there is no way to document whether it works or not. I use it too, so I am not opposed to it. Anecdotal stories like those here are nice, but they are not rigorous tests.
1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
05-17-2023, 04:21 AM | #85 |
Re: MMO in the Gas
I know some love MMO and some do not but regardless I think keeping the gas tank full helps assuming your tank is in good shape......and i do not see how MMO hurts.
05-17-2023, 06:11 AM | #86 |
Re: MMO in the Gas
05-17-2023, 12:28 PM | #87 |
Re: MMO in the Gas
With all due respect, I think personal experience can be interpreted as "knowledge". It seems like most of the posts on the several pages of this subject are mostly based on personal experience, whether positive or negative. A product that has been around a hundred years certainly has a strong and loyal customer base to survive, spanning several generations. Not too many products can boast about that. Whether it's a great product, or snake oil...people still buy it because they think it works.
Stickshift 1915 Model T touring 1931 Ford Model AA Flatbed |
05-17-2023, 02:10 PM | #88 | |
Re: MMO in the Gas
I owned the car that I am referring to for 43 years. The first 20 years I did not use MMO or HD oil. Switched over, and within 100 miles most of the valve noise went away. Within 500 miles it was gone. Sold the car last year, no valve noise. A few years ago I purchased a car that had been sitting for a number of years. When we started it up it sounded like the valves were going to explode. Changed the oil to 20W-50 HD and put MMO in gas. After about 200 miles noise was almost gone. I don’t need rigorous tests. I like first hand results. We’re not going to the Moon here. Enjoy. |
05-17-2023, 03:09 PM | #89 |
Re: MMO in the Gas
Bang, Right to the moon Alice... https://youtu.be/98qw86DsdZ0
05-17-2023, 04:00 PM | #90 |
Re: MMO in the Gas
A funny story... I know this MMO subject has been beat to death, but it reminds me of someone I met many years ago. I was in a pizza parlor and when I went to pay the man at the register, I slowly reached out my arm and said my elbow has tendinitis (tennis elbow). The man at the register said "Oh you should rub some WD-40 on it" I said "What"? He said "Yes, I use it all the time for my arthritis". I said "You actually put it on your skin"? He swore it works. I know the makers of WD-40 would be the first to disclaim topical use, and there are no clinical studies to support this, but this guy would go to his grave claiming it worked for him...and who am I to say he's wrong?
05-17-2023, 04:23 PM | #91 | |
Re: MMO in the Gas
Ruth "Sometimes you really DO need to read the whole thread" |
05-17-2023, 07:14 PM | #92 |
Re: MMO in the Gas
05-17-2023, 08:15 PM | #93 |
Re: MMO in the Gas
Upper cylinder lubricant as we used to call it smelt like almonds. Does MMO smell like that? I've never seen it here but I looked it up. A one US gallon (3.78 litres) pack cost $100. I guess I'm not in a hurry to find out how it smells.
05-17-2023, 09:17 PM | #94 |
Re: MMO in the Gas
MMO works so good it freed up a stuck distributer for me. I bet if you dumped some in an empty tank and let it sit in different positions it would remove rust.
05-18-2023, 06:50 AM | #95 |
Re: MMO in the Gas
Yup, rub some on your joints, it’s good for arthritis, rheumatism, lumbago and melancholy..
05-18-2023, 07:16 AM | #96 | |
Re: MMO in the Gas
Therefore, EXACTLY WHAT did the Marvel Mystery Oil do to "exploding valves" (-whatever that sounds like?? ) to make the exploding sound go away? Since the Model-A engine uses a mechanical tappet, it generally is excessive lash clearances that causes a valve noise. From my vantage point, it is more likely that a higher viscosity oil would cushion the impact of the tappet hitting the valve stem, ...yet I would think that MMO being a thinner viscosity, it would not help in abating that valve noise. If that was not it, then what other scenario would cause the valves to explode?? |
05-18-2023, 07:37 AM | #97 | |
Re: MMO in the Gas
I was just using the word exploding to over emphasize the clatter that the valve train was making. There were no explosions going on with the exception of normal cylinder firing. My point is that there very well could be a correlation in using MMO along with HD oil to help free up your valve train. Slow, sticking, worn. Say whatever you like! I really think that it has worked for me. The proof is in the pudding. Valve noise was reduced significantly. That’s all I cared about. Enjoy. |
05-18-2023, 03:58 PM | #98 | |
Re: MMO in the Gas
David Serrano |
05-18-2023, 04:44 PM | #99 |
Re: MMO in the Gas
I remember that one! He said it attracts women. (LOL) I'm thinking mosquitos too! Seriously...how long is this post going to last? I know I'm not helping to end it.
05-18-2023, 05:28 PM | #100 |
Re: MMO in the Gas
When I was a kid “Guy Lumbago and his Orchestra” played at Jones Beach… he was a spokesman for Marvel, why his last name alone sold gallons..
