04-21-2023, 08:05 PM | #41 |
Re: MMO in the Gas
04-21-2023, 10:47 PM | #42 |
Re: MMO in the Gas
04-21-2023, 10:50 PM | #43 | |
Re: MMO in the Gas
Terry |
04-22-2023, 06:46 AM | #44 |
Re: MMO in the Gas
The elixir was was TCP, Tricresyl phosphate, of which there is a small amount in MMO.
04-22-2023, 06:58 AM | #45 |
Re: MMO in the Gas
I stopped using placebos when extra-strength placebos became available. Much, much better.
04-22-2023, 07:32 AM | #46 | |
Re: MMO in the Gas
04-22-2023, 08:54 AM | #47 |
Re: MMO in the Gas
04-23-2023, 05:58 PM | #48 |
Re: MMO in the Gas
In reference to [email protected]. I also use MMO in my gas due to vapor locking. I had a '29 Chevy that also use to vapor lock even with a mechanical fuel pump. Once I added MMO no more vapor lock. It can get very hot here in Florida.
Bob-A Skirts are for women and not car fenders! |
04-24-2023, 07:44 PM | #49 |
Re: MMO in the Gas
I have always put 4 oz of MMO per 10 gal of gas when I fill up. I really don't know if I'm getting a benefit, but I don't really care and I'm not going to stop. It is part of my ritual of fueling my car and adds to the mystique of owning/driving an antique car. I love how people at the neighboring pumps watch me as I carefully measure the bright red liquid, pour into the cowl tank opening and then clean every drop from my measuring cup and the neck of the gallon jug of MMO. I stow the cup, jug and towels in a special secured spot in my trunk (my '30 coupe has had the rumble seat replaced with a trunk). When people ask me what I'm doing and why, I tell them that it is a "mystery"; possibly connected with Voodoo, and if I reveal the secret I may lose my juju.
PS: Marine fuel without ethanol is readily available in my area, so that's what I use. If I'm cruising, I just use any regular gas. I also throw salt over my left shoulder if I should spill some. Some things just won't hurt, but you never know. Keep smiling. |
04-25-2023, 10:17 AM | #50 |
Re: MMO in the Gas
Maybe some MMO taken in small quantities will help with the slipping ?
Always one bad decision away from a good time. |
04-25-2023, 11:02 AM | #51 | |
Re: MMO in the Gas
Very, very well written! I like that sort of mental life, it's rituals that we celebrate on our iron cars.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
04-25-2023, 02:05 PM | #52 | |
Re: MMO in the Gas
04-25-2023, 02:11 PM | #53 |
Re: MMO in the Gas
Hey Y-Blockhead, could you please increase your letter size by at least 50%, it would help with old tired eyes reading your posts. I do like the green letters! :-)
04-25-2023, 03:24 PM | #54 |
Re: MMO in the Gas
04-26-2023, 12:22 AM | #55 |
Re: MMO in the Gas
Terry, Moth balls are Naphthalene, C10-H8, a hydro carbon, produced from coal tar which crystalises into a white substance then used to evacuate pesky cloth munching insects in your wardrobe/closet. It was at one time called white tar. Sorry for the chemistry lesson, it still smells nice, reminds me of a well kept bedroom and best Sunday suite.
I make a type of MMO using some info gleaned from MSDS (material safety data sheet). My mix is Six parts marine two stroke outboard motor oil, added to Four parts auto transmission fluid, to which add a small amount of Salacylic Acid, (oil of winter green) add the mixture in the same portions as MMO. Cheers Rob GIMG_6456.jpg IMG_6468.jpg
Tassie Devil |
04-26-2023, 05:08 AM | #56 | |
Re: MMO in the Gas
04-26-2023, 09:26 AM | #57 | |
Re: MMO in the Gas
Terry |
04-26-2023, 04:11 PM | #58 | |
Re: MMO in the Gas
It is a low-viscosity gear oil with a increase coefficient of friction (!) and high-pressure additives. These tend to form particularly strong tar and sulfate ash forms from this. In the long term, this leads to glass-hard deposits on the piston crowns and the valve stems on the exhaust valve. (Motor oils are more refined, contains other additive packages designed for almost deposit-free combustion, as well as cleaning additives and detergents.)
04-26-2023, 06:24 PM | #59 |
Re: MMO in the Gas
Thank you Ron and Werner. It looks like I will have to re think the contents of my home made MMO. I do have some genuine MMO. I had to order it from an Aviation supply company, then it is shipped to the ordering co, and at A$80.00 per container it is not cheap. I bought it on the recomendation of my aircraft mechanic to use un my Auster aircraft.
Tassie Devil |
04-26-2023, 06:36 PM | #60 |
Re: MMO in the Gas
Since it is aircraft, it is good to rethink. I think instead of paying ransom I would find a recomended (by the arcraft suppliers), top oil and then add the wintergreen oil. Now it will work and still smell great! I don't know what brands they sell where you're at, maybe seafoam, maybe some other tried and true product that won't bring any lawsuits if the unfortunate should happen.
Thread Tools | |
Display Modes | |
