04-11-2023, 03:43 PM | #1 |
Bogging down in third
Howdy Yall, got a question for you. last time I drove my 31 pickup, it developed a bad habit of bogging down in third gear from 13-30 mph. it has the 4.11 gears outback, and it shouldn't bog down. timing is good, no brake drag that i know of, first and second are pretty good. now I shift into second at 9 mph and into third at 13-15 mph since it has the lower rear gears. so, what's up with it? doesn't seem to be the carburetor but I will sometime put a marvel on it and see if it make a big difference (it has a zenith currently). also, when descending a hill, it likes vibrating a bit when letting off the throttle. Is this normal for an A or is this worth looking into? thanks for your time
"Quality means doing it right when no one is looking" Henry Ford |
04-11-2023, 04:07 PM | #2 |
Re: Bogging down in third
Sounds like it could be a fuel issue. Where is your GAV set? Try opening it a bit. Loosen the gas cap in case you have a vacuum in the tank. Check for fuel flow at the bottom of the carb then at the side where the line goes into the bowl.
You said it doesn't seem to be the carb, what makes you think that?
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
04-11-2023, 04:12 PM | #3 |
well, i drilled the gas cap so vacuum isn't the problem, and I flow tested the jets and set it all to specs. and I have the gav open when warm about 1/8 turn or just a smidgen open. I tried fiddling with the gav, but it seems to not like over 1/4 open, so it might be running a tad rich. and flow form the sidebowl on my zenith is really good and the tank is clean as a whistle, no rust and no trash in the carb.
04-11-2023, 05:11 PM | #4 |
How is the gas level in your float bowl?
Millions of Model As ran fine on the Zenith carb, I see no reason to switch to a Marvel (altho I have one...). |
04-11-2023, 05:17 PM | #5 |
The vibration while decelerating can be caused by a bad U-joint, loose bolts in the U-joint clamshells or a loose pinion bearing nut. The bolt securing the U-joint to the transmission rear shaft could also possibly be loose or the special notched washer beneath the bolt head was forgotten. These problems miraculously "disappear" when accelerating because of the torque being applied against them. When the torque is released, any or all of these parts manifest themselves in vibrations.
Marshall |
04-11-2023, 05:25 PM | #6 |
Vibrating a "little" while backing off on the throttle could be normal depending on how much a "little" is. Or as Marshall talked about, it could be an indication of something amiss in the drive train.
04-11-2023, 09:01 PM | #7 |
Thanks a million, to all who replied. so as far as i know, gas level is correct in the bowl, since I had an experienced carb man at my club put it together since he is so meticulous. as for wanting to put a marvel on it, that comes from wanting to squeeze my fuel dollar further and keep the zenith as a spare under the seat. I got a free marvel from a friend that need a few things, so it's me wanting to experiment. as for timing, i fiddle with it constantly to keep the engine at top efficiency. I'm not one to run full advance all day. I usually run about halfway to 3/4 on the advance since I don't drive fast. now, as for compression, its good. Got a bone stock engine and it seems to run fire. the vibration only hits on deceleration at speeds over 30, under that it won't. this vibration has been with the car since I first drove it at that speed, which was after I bought it, so it wasn't sudden to my knowledge. it feels like it might be from the u joint forward because it seems to vibrate the front and floor under the seat more than the back end. it can best be described as a frequency vibration that's akin to an engine rev spot. the frequency is faster than tire shake, closer to an engine vibration or something driveshaft related. not so bad mirrors fall off or anything, nor is it tire related since I keep my tire pressure correct and they have been balanced. so, its drive line related in some way. I theorized it could be something like loose hardware, but only way to know is pull stuff and I am not in the position to do that right now as I am using the truck regularly with my old chevy car. I am praying it isn't flywheel or something bad, hopefully it's something easy to fix.
04-11-2023, 09:07 PM | #8 |
oh, and postscript, it rolls EASY. like so light you can push with one hand on level ground easy. brakes just got done, nothing dragging and all grease points topped up nicely. so its not bogging down from that, and it feels nice in first and second, but go to third and it acts like its too tall. other club members a's I have driven act more peppy in third. mine puts its tail in its legs and goes "do I haaaaave to?" lol
04-11-2023, 09:51 PM | #9 |
Clogged exhaust, aka mouse house, muffler falling apart on the inside. Throttle plate not opening fully, aka bent linkage, many years ago my A wouldn’t go past 45 mph going down hill with a tailwind ( throttle plate was opening fully).
04-12-2023, 07:50 AM | #10 |
Sunny, I've recently been tweaking motor mounts. (Float A Motors/FAM) What mounts do you have and are the rubbers old and hardened? What front mount do you have. There is a leather washer that goes under the front yoke that sticks down through the front x member. Snyder's or Bratton's has exploded views on their website.
04-12-2023, 08:14 AM | #11 |
As I remember, 15mph is lower than the Model A Instruction Manual calls for shifting into 3rd. 4-11 gears would help this, but try shifting out at 18-21mph???
Your 13-30mph is the low speed range of the carb. The CAP jet circuit in combination with the Compensating jet, Secondary Well, and GAV are supplying the largest percentage of fuel to the Venturi at that speed range. The Secondary Well, the brass insert, supplies the idle speed range with fuel, but it also supplies a brief surge of fuel when transitioning from idle to low speeds. (similar to an accelerator pump on later carbs) If your issue is a brief stumble when stepping on the gas in 3rd gear from 15mph, our coupe will stumble in cold weather, (below 55* F) if I have the GAV too tight. A small as 1/8 or so turn further open stops this. (Model A Zenith carb) Carbs vary due to jets and many other variables, but running with 1/8 th or less turn open seems tight, as in lean. Sooty powdery black plugs would be rich You might benefit from resetting the base idle.
04-12-2023, 10:25 AM | #12 |
as for engine mounts, all bone stock. no float a motors. my engine is firing on all plugs and it seems to just not have quite enough grunt at those speeds. if I stamp down on the throttle it will pull fairly well but it really takes off after the 30 mark. if i set the hand throttle at say 30, the engine occasionally makes a slight misfire every now and then, almost indistinguishable unless you listen closely. it's a low popping sound coming from the muffler, sounds like a lean burn or air getting into the muffler. its getting full throttle and all linkages were checked and the idle seems sufficient.
04-12-2023, 10:29 AM | #13 |
In high school, a dirty trick to play on someone was to jam a potato up the exhaust pipe. The car would hardly idle, much less accelerate.
04-12-2023, 10:38 AM | #14 |
well, thankfully it doesn't have that problem of a dam tater in the tailpipe. but I might take the muffler off and hose it out to be safe you know? my used to run really smooth at 30 without that faint muffler pop, but after a while it starting happening, however the sluggishness was present before that.
04-12-2023, 10:42 AM | #15 |
Why not ask him to diagnose it ?
04-12-2023, 11:18 AM | #16 |
because he is swamped with em, got 7 carbs in ahead of me and i did an inspection of all the heights, and I gave him flow tested jets, by all accounts it should be fine. but those zeniths are so finicky it isn't funny.
04-12-2023, 07:14 PM | #17 |
Here is a good site about the Zenith carburetor: https://model-a.org/
Here is their symptoms guide and the first topic is problems with driving over 30 or 35 mph. https://model-a.org/symptoms.html
04-12-2023, 07:34 PM | #18 |
the sluggishness in third might be the comp jet from what I read. it might not be getting the correct fuel mixture. but when i get the truck back together as i took the brakes apart, I'll be able to give y'all better descriptions of the ailments. maybe sitting waiting for brake parts will teach my A a lesson hahaha
04-12-2023, 09:27 PM | #19 |
While it is sitting waiting for parts pull the carb off, split if in half and use compressed air to blow through the jets and passages. Easy, quick and simple to do.
Dave / Lincoln Nebraska |
04-13-2023, 08:12 AM | #20 |
good idea, i just happened upon a scrap air compressor that'll do the trick, so I'll blow it all out in the meantime while the brakes are going back together.
04-13-2023, 04:41 PM | #21 |
ok yawl, got the wheels on the truck and am going to adjust the brakes tomorrow as it's raining now. got the truck running and I'll be dammed if it aint running like a sewing machine. no sputter, no backfiring. now this was just sitting in the carport, but my instincts tell me it will run well when I do the test drive. I set the gav between 1/8 and 1/4 turn open and it just purred. I'm thinking that bogging down might have been something clogging the compensator, but we shall see. Fingers and toes crossed. Maybe Sunny is just happy to be running again, who knows.
04-14-2023, 06:59 PM | #22 |
ok yawl, here is the scoop. I got the brakes working and I took it around the block, when the gav was open about 1/8 turn open, and shifted into third at 18, I could firewall the throttle and it pulls firmly, much better than before. after driving a while with temp gauge registering 160-170, it seemed to lose a bit of pep, but that might just be the gav needing a bit of fiddling. now when letting off the gas to shift it still pops a bit in the muffler. so Sunny is still being a Wiseguy. so, tell me, what's up with it?
04-14-2023, 09:26 PM | #23 |
Did you blow out the jets and passages and if you did do you think that this is something that helped?
As far as the popping on deceleration I would suspect a leaky gasket on the intake manifold. Spray some starting fluid all around the gasket mating surfaces of the intake/exhaust manifolds when the engine is running at idle to see if the engine speed changes when doing so. If it does then you have a leaky gasket.
04-15-2023, 07:32 AM | #24 |
i checked em and blew the jets out a bit, and it did seem to help. as for gasket leak, not surprised. my manifolds probable not perfectly flat. so today I'll take em off and file em a bit if need be. let me tell you, going through the brakes entirely is the best decision on that a model one can make. it stops on a dime and gives seven cents change.
04-15-2023, 04:03 PM | #25 |
Sunny, if you remove the manifolds, lay them on the bench and check for flatness with a metal, straight edged square. Check that the holes are in line. #4 exhaust is often drooped. You'll need a machine shop to fix the flatness unless its a burr or something. My old manifold was drooped front and rear!
04-15-2023, 05:40 PM | #26 |
