03-29-2023, 07:23 PM | #1 |
Wiring distributor for start up
I am getting ready to start up a model A engine that has been sitting for awhile,
What is the easiest way to get power to the distributor? ( I do not have a pop out switch yet) Do I need to get the A11575 J ignition cable ? Thanks in advance for the help. |
03-29-2023, 07:48 PM | #2 |
Re: Wiring distributor for start up
03-29-2023, 08:33 PM | #3 |
Thanks
03-30-2023, 07:32 AM | #4 |
A simple no cost method:
Attach a wire with a connector to the curve plate mounted on top of the lower plate inside the distributor. There should be hole in the curved piece where it can be attached with a small screw and nut. Run the wire out through the large tapped hole in the side of the distributor to one side of your key switch or you can use a simple single throw toggle switch. Connect another wire to the other side of switch and connect it to the + terminal on the coil. This is assuming you are using a (+) positive ground. Run another wire from the (-) terminal on the coil to a (-) terminal connected to the battery or the starter motor connection. |
03-30-2023, 02:09 PM | #5 |
and here's a diagram, just a wire from live battery to coil then a wire from coil to points If you use a croc clip on one of the wires it'll be easier to stop it once it's started!
03-30-2023, 03:26 PM | #6 | |
