05-14-2010, 07:01 PM | #1 |
Update on head
Well, I was able to get all but two studs out. I was not pleased to find I also have two with heli coils in them, at least the studs came out of these.
First things first, any suggestions on how to get the last two studs out without breaking them. I've soaked them in PB Blaster for 3 days. Second, any suggestions on what to do with the holes that have heli coils? I'm not sure I want to screw back into those... Block and piston cleaning is going ok, and the head is at the machine shop getting magnifluxed and resurfaced. |
05-14-2010, 07:07 PM | #2 |
Re: Update on head
If helicoils are installed properly, they are fine. You could try some heat on the studs that are stuck. Heat them red, then let them cool before trying to turn them.
05-14-2010, 07:23 PM | #3 |
Re: Update on head
i have had luck this way:after heat/cooling, rap the top of the bolt with a hammer a couple of times, then use a pipe wrench as close to the block as possible. try loosen/tighten, loosen/tighten with a lot of luck and a little skill: presto!
05-14-2010, 07:35 PM | #4 |
Re: Update on head
whats wrong with a properly installed helicoil?
05-14-2010, 07:42 PM | #5 |
Re: Update on head
I found that "KROIL" works even better than "presto"
05-14-2010, 07:45 PM | #6 |
Re: Update on head
05-14-2010, 07:57 PM | #7 |
Re: Update on head
I'm good with using the heli coils if you think it isn't a problem. I had just heard that they don't hold up with 55 pounds of torque. I really don't much about them.
Quote from cannon...i have had luck this way:after heat/cooling, rap the top of the bolt with a hammer a couple of times, then use a pipe wrench as close to the block as possible. try loosen/tighten, loosen/tighten with a lot of luck and a little skill: presto! Thanks for the advice on the heat. Sounds like patience is a good thing to have also... |
05-14-2010, 07:59 PM | #8 |
Re: Update on head
Just heat and cool those studs, lots of juice, they will come eventually. Use a pipe wrench close to the deck.The helicoils are fine!
05-15-2010, 08:04 AM | #9 |
Re: Update on head
If you try using heat, an old mechanics trick is to heat the stud just till it will melt wax, let the wax flow into the threads, let it cool and the stud should turn out realatively easy.
05-15-2010, 09:58 AM | #10 |
Re: Update on head
I've also heard excellent rusults using the wax method. I need to remember to try it the next time I have a stuck stud.
05-15-2010, 01:52 PM | #11 |
Re: Update on head
05-15-2010, 02:32 PM | #12 |
Re: Update on head
Others have mentioned mixing automatic trans fluid and acetone, say better than kroil
Paul in CT |
05-15-2010, 04:27 PM | #13 |
Re: Update on head
05-15-2010, 05:50 PM | #14 |
Re: Update on head
I have removed as many as 140 studs in one day and only broke 2. I figure that's pretty good odds. I don't heat the stud but only heat the block as much as possible. I use acetone and ATF or PB Blaster when the block cools enough to not set the fluid on fire. I also use Jim's method of a pipe wrench close to the block and have a fine feel for studs that are weak. That feel is the most important and refined over the last 40 or more years.
05-15-2010, 07:40 PM | #15 |
Re: Update on head
A mixture of half and half acetone and ATF is probably the best penetrant
known at this time. Wax is good but it requires heat and heat applied indiscriminately is bad. We cut the broken stud off close to the surface and machine it out in the mill. Takes no more than 5 minutes per stud. Heliciols properly installed will last forever unless the base metal is absolutely rotten. They will take at least twice the maximum specified torque for the screw.(don't try that though) On blocks where the base metal is completely rotten or it has been previously tapped oversize, we bore it and put a steel plug in. On modified engines we plug all the head stud holes. |
05-15-2010, 08:00 PM | #16 | |
Re: Update on head
And could you define "modified"--at what level do you plug all the holes? Thanks. Joe
1929 Tudor since 1962 Feather River A's |
05-15-2010, 08:47 PM | #17 | |
Re: Update on head
If I am putting an aluminum head on I plug all holes.. I use aluminum heads on all my modified flathead engines. They are easier to modify than the iron ones. For these applications I make studs from 4340 bar stock. It's all these LITTLE things that save you headaches down the road. |
05-18-2010, 03:33 PM | #18 |
Re: Update on head
Most people don't have pete's equipment to remove a broken stud and it's hard to centerpunch the rough top of the broken-off stud(stud-stub?). If you put the head back with some other studs and reduce the size of the stud hole with a piece of 1/4"pipe or tubing cut even with the surface of the head.then you can drill in with a long 1/4" bit enough to get an easy-out in.The 1/4' bit will take out enough material you might not even need the easy-out.
05-18-2010, 04:36 PM | #19 |
Screw up good this time.
I thought I was doing such a great job. Center punch the broken stud dead center drilled it out starting with a 1/4" drill and progress until I could see some threads.Ran a flat bottom tap down in thinking I was just chasing the thread. Everything look good until I ran a stud down the hole. the hole came out crooked and stud leans towards the outside of the block. NOW what can I do to fix it ?
Last edited by Richard/Ca; 05-18-2010 at 04:43 PM. Reason: Posted in the wrong place.such have been new thread. |
05-18-2010, 05:32 PM | #20 |
Re: Update on head
"form" it verticle ?
Paul in CT |
05-18-2010, 05:46 PM | #21 |
Re: Update on head
Richard,
I think you're going to have to do it again. They sell an attachment that goes on your drill. This thing looks like a large thick washer with two studs coming off it that clamps to your drill. If you're handy you can make it up. Then what I would do is use an EZ-Lok plug in it.. Just a suggestion I'm sure Your going to get a few suggestions from the boy's Last edited by Bob A.; 08-04-2010 at 09:30 AM. |
05-18-2010, 05:49 PM | #22 | |
Re: Screw up good this time.
Clean the hole with acetone. Install the stud with green Loctite. Let it sit overnight. Next day bang the stud straight with a rubber hammer. Best method: Take it to a machine shop and have the hole repaired with a steel plug. Next time: Bring it to me to fix...It would only have cost you $10. |
05-18-2010, 07:54 PM | #23 |
Re: Update on head
I tend to agree with you Paul. Richard is the stud tight in the hole? That would be my solution if it is but I'm dealing with an engine that will be rebuilt in a coupe years anyway.
05-18-2010, 08:37 PM | #24 |
Re: Update on head
Strip the block down to nothing, and take it to a machine shop and have them put in a thick walled insert. The crank has to be out so they can set it level on the mill, they they can drill it straight and square.
05-19-2010, 09:43 AM | #25 | |
Re: Update on head
Jim don't you think thats a little bit of work for one stud? Maybe later on when he's going to do a major overhaul. |
05-19-2010, 10:36 AM | #26 |
Removing stuck head and manifold studs "wax method"
The wax method I use: Heat the stuck stud cherry red as close to the block surface as possible without doing damage to the block. Let the stud cool to the point that when a wax candle or canning wax block is held against the stud the wax flows down quickly to the block surface without producing smoke. If the stud is to hot, it will flow but much of it goes up in smoke. At this point I will strike the top of the stud a couple times with a hammer and then apply wax again. Let everything cool to room temp and then try to remove the stud. Most of the time it will back right out. If it is still stuck, repeat the process. I have only broken one stud since I was clued in to the "wax method" by a fellow Club member. Good Day! Dave in MN www.durableperformance.net |
05-19-2010, 10:52 AM | #27 | |
Re: Update on head
Good Day! Dave in MN |
