Old 05-31-2023, 06:16 PM   #1
AL in NY
AL in NY's Avatar
Default 27% OD gearset for sale for Tremec RTS transmission
I have just upgraded my F150 Tremec RTS to the "Goldilocks gearset. I have a shortened 21 tooth input shaft, an 18 tooth OD gear and a 32-35-23-15 cluster gear which will change any RTS transmission to a 27% OD transmission. The gear ratio will be......3,25-1.92-1.00-.783. Message me for price.
AL in NY
AL in NY is offline   Reply With Quote
Old 11-10-2023, 08:04 AM   #2
diyforever
Default Re: 27% OD gearset for sale for Tremec RTS transmission
Al, I acquired 31 slant window with F150 RTS. Needs clutch disk. Took engine out. Noticed RTS has a 8 7/8 clutch disk with 1 1/16 input spline. Would you know what car/truck the disk came from?
diyforever is offline   Reply With Quote
Old 11-10-2023, 10:17 AM   #3
AL in NY
AL in NY's Avatar
The clutch is from a 1986 Ford Thunderbird with the 2.3L turbo. Check to see if this 9" clutch will work for you.
AL in NY
Old 11-10-2023, 12:43 PM   #4
CarlG
CarlG's Avatar
I am using a Ft Wayne Clutch Part # CD0924 on mine.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-12-2023, 09:39 PM   #5
diyforever
Thank you both for your help. I should have also asked if you know what type of throw out bearing this is. Here is a picture. It doesn't appear to have a number on it. Trying to attach photos of bearing still attached to hub. Hope it works..
