Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 07-01-2019, 08:49 AM   #1
Huff
Send a message via ICQ to Huff Send a message via AIM to Huff
Default Stiff clutch pedal
I put a new clutch and pressure plate 11" in a 52 ford f1 and the pedal pushes hard.The truck had a 11" clutch in it before. Not a pleasure to drive. I have new brass bearings all have been greased.The old clutch did not push hard but had bad clutch chatter. Fly wheel was resurfaced all linkage is good. Any help other than put in a 10" pressure plate and clutch. Thanks Huff
Huff is offline   Reply With Quote
Old 07-01-2019, 10:13 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Stiff clutch pedal
You need to ask on the Early V8 forum. This section is not for car questions.
Old 07-19-2019, 09:42 AM   #3
Orich
Not all clutches are the same poundage like the half ton or a 3/4 tons. Since these are old classic vehicles the supplier may only can get one so they don't have to stock two styles. Green sales may have an OEM pressure plate. Or have the Pressure Plate replaced the-spring..
Orich is offline   Reply With Quote
