Old 01-10-2013, 10:01 PM   #1
Mtn Wudy
Mtn Wudy's Avatar
Default Firewall grommet cover..
Hi Guys n Dolls too I guess...
I'm new here,but not to OldCars...my question is ,does my 1948 or should I say should my car have a "Cover" where the main wire loom exits into the engine compartment ,like a 40 does....Thanks ahead of time...
Mtn Wudy is offline   Reply With Quote
Old 01-10-2013, 11:19 PM   #2
Old Henry
Old Henry's Avatar
Default Re: Firewall grommet cover..
No. It looks like this:
Old 01-10-2013, 11:49 PM   #3
Mtn Wudy
Mtn Wudy's Avatar
Yes....I saw those two holes in firewall and wondered if a cover went on there ...I was looking at eBay and saw a "Cover for a 1940" and got me thinking maybe my car should have one....I know it wouldn't be the same since the one for sale was half/egg shaped...I've only had this car for three months....Older restored 1948 Ford Station Wagon....I've put new water pumps on it ,and want to put a stock fuel pump back on....The electric one on there now is louder then the engine I swear....Carl
Old 01-10-2013, 11:53 PM   #4
Mtn Wudy
Mtn Wudy's Avatar
Oh and thanks for a quick response ..I enjoy you "travel Photos".....Carl in Lake Arrowhead Ca..
Old 01-11-2013, 12:04 AM   #5
ford38v8
ford38v8's Avatar
Look at that, will you? Old "Electrician Tape" Henry is way over an hour late in answering, and he gets a thank you for a quick response!
Actually, we all thank Mtn Wudy for his reply to Henry. Some questioners never acknowledge a whole crew of responders with gobs of useful information.
Alan
Old 01-11-2013, 12:16 AM   #6
bobH
And... Welcome, to, and from, Arrowhead. I'll be watching for the Wagon. Maybe at the Woody show in June??
bobH is offline   Reply With Quote
Old 01-11-2013, 01:04 AM   #7
Mtn Wudy
Mtn Wudy's Avatar
BobH...You'll see me and if you've been there the last five or so years you've seen my 1920 Model T Ford depot hack ....I have it up for sale to make room for the Woodie....I only have room for one Toy at a time......I'd like to invite everybody to come up in June....When it gets closer ill post the dates....Carl
Old 01-11-2013, 01:51 AM   #8
peewee2you
peewee2you's Avatar
Mtn Wudy, althought a 40 does have the metal cover, the 46-48 as for my knowledge does not and didn't use a metal cover, only the rubber grommet that Old Henry shows in the photo above. I have a 47 and thought the metal style cover on the early 40's style would look nice and clean, and so I purchased an old one that had been bead blasted etc., and then tried to apply it to the fire wall and because the wires distribute somewhat different from the earlier Fords, couldn't seem to get that to happen, probably why you don't see those years with the metal cover. The two holes are there because the same body is used, but those two holes utilized on these years. What I did do because my wiring was all replaced but when they replaced the wire the cut the inside firewall pad which helps in holding the rubber grommet tight against the firewall all together. I saw that the later years 50's used a metal ring and those two screw holes to hold there wire loom in place and they are a split unit which allowed me to secure that and clean up the look that I wanted. Below is a photo.
macsautoparts.com has them $9.95, Ford 49-59 item# 8A-14608 called Main wiring loom grommet retainer, under the electrical and wiring section, then wiring page 4.
peewee2you is offline   Reply With Quote
Old 01-11-2013, 01:53 AM   #9
peewee2you
peewee2you's Avatar
I meant to write that the two holes you see on the firewall on each side of the rubber grommet are not used on those years...
Old 01-12-2013, 01:56 PM   #10
rustythumb
i think covers were used up untill ww2, but not after. the '41-'42 covers are a bit different than the '39-'40.
rustythumb is offline   Reply With Quote
Old 01-13-2013, 09:56 PM   #11
meric42
meric42's Avatar
I think that you'll find that the covers were used on '41, '42 and up to early '47 I believe.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 01-13-2013, 10:15 PM   #12
meric42
meric42's Avatar
Here is a picture of an original '42 bulkhead with the said cover in place to support my statement above
