11-16-2012, 04:44 PM | #1 |
Brakes: 39-42 vs 46-48
By design, the 46-48 brakes, with their fixed lower anchors and floating shoes, eliminate the need for periodic adjustment of the lower shoe anchors as in the 39-42 type. The no-adjustment feature appears to be an advantage - keeping the brake in proper adjustment for a longer period (?) or maybe just a convenience factor for lazy people like me. I would like to hear from Fordbarners that have used both types and hear their opinions as to what the tradeoffs are. Thanks.
Those who do not move do not die, but are they not already dead? |
11-16-2012, 05:00 PM | #2 |
Re: Brakes: 39-42 vs 46-48
46-48 are far better IMHO than 40/42s. Even better are the bendix backing plates sold by several vendors.
11-16-2012, 05:22 PM | #3 |
I have a '39 CS and also a '47 Convertible, and I much prefer the later'42-'48 brakes as they are easier to set up and adjust.
11-16-2012, 05:29 PM | #4 |
Agreed. I have 39s on the front and 47s on the rear. The 39s are a pain.
11-16-2012, 05:29 PM | #5 |
The later is definatly quicker and easier but if the early ones are done correctly I think you can achieve better contact between the shoe and drum. Of coarse the real way to do it is to have the shoes arched or ground to fit the drum for optimum contact area but no one can do this anymore ,at least not around here.
11-16-2012, 06:07 PM | #6 | |
Cheers Tony |
11-16-2012, 06:24 PM | #7 |
Arcing the shoes is good for either type of anchor. But, like you say, its hard to find people or equipment to do this nowadays.
11-16-2012, 06:38 PM | #8 |
There a brake shop here in Ocala Fl that still match grinds the shoes to the drums, and the price is reasonable. If anyone is interested, I'll get there infomation.
John |
11-17-2012, 09:44 AM | #9 |
I've read of a method for arcing the shoes where you put a sheet of sandpaper between the new shoe and the drum, and arc it by moving the shoe back and forth by hand until the contact is completely even-haven't tried it myself, though
Adam
1936 pickup, stock, black 1965 Mustang coupe 289/4bbl, black/red 1971 Alfa Romeo GTV 1750 coupe, dark red/tan 1970 911E 2.2 litre dark blue/black 1968 BMW R50/2 US, black (m'cycle) 1967 Triumph TR6R , sea foam/cream (m'cycle) 2022 Royal Enfield Interceptor 650 red (m'cycle) 1974 Honda CB750 red (m'cycle) 2000 Kawasaki W650 blue/silver (m'cycle) |
11-17-2012, 11:40 AM | #10 |
Using adhesive backed 2 3/4" sanding paper works great. I used on my A also. Zeke
Only problem with retirement is never a day off |
11-17-2012, 11:44 AM | #11 | |
Charlie Stephens |
11-17-2012, 03:09 PM | #12 |
11-17-2012, 06:40 PM | #13 |
This thread got a little off-topic. Any more comments on 39-42 vs. 46-48 brakes? Thanks for your advice/comments!
11-17-2012, 08:29 PM | #14 |
i replaced the rear '39-'42 to '46-'48, much happier, the front will be done soon,
and any big rig shop that rebuilds clutchs and brakes should be able to reline your shoes (they line the hole shoe) cut the drums and arc the shoes to each drum. rich |
