Old 01-29-2021, 08:56 PM   #1
Detonator
Detonator's Avatar
Default ‘35 window crank knob removal?
I’m working on the interior of my 5W and would like to pull off these ivory knobs and clean up the arms. How do you get the knobs off? Do I need to drill out the pins from the back? I see these pins are available from 3rd Gen so I’m guessing they get destroyed in the process. Thanks.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 01-29-2021, 09:12 PM   #2
FritzJr
FritzJr's Avatar
Default Re: ‘35 window crank knob removal?
You should be able to drive the pins out with a proper size punch. The pins should be re-usable if you don't lose them.
FritzJr is offline   Reply With Quote
Old 01-29-2021, 09:36 PM   #3
Brian
Brian's Avatar
I've levered them off with two little screwdrivers, one each side. They're simply pushed onto the splines on the pins.
You didn't say, but I'm assuming you mean the ivory knobs on the window winder arms.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 01-30-2021, 01:05 AM   #4
Detonator
Detonator's Avatar
Yep, the ivory knobs. Thanks. I'll do the levering off. I really want to save the originals.
Seabright Hot Rods
Old 01-30-2021, 02:05 AM   #5
deuce lover
deuce lover's Avatar
Warming them up in hot water might help.
deuce lover is offline   Reply With Quote
