Old 04-04-2021, 11:34 AM   #1
Anteek29
Anteek29's Avatar
Default Brain Fade!
Went to start my '41 PU yesterday - all went fine, except I got distracted and forgot to switch the ignition to ON. Cranked and cranked...battery was weak to begin with but I recovered my error too late.
Then put on the charger. Got the polarity correct but the negative clip was on the solenoid side of the battery disconnect clamp (that I had opened as part of the charge procedure) and I wondered for a bit why the charger indicated zero amps output? DUH! Relocated the neg clip to the battery post side and all was good. I just shook my head in disbelief and went to lunch. Can't win some days I guess
Oh, yes, Happy Resurrection Day!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 04-04-2021, 12:06 PM   #2
1ton
Default Re: Brain Fade!
Normally, a guy would look around to see if anyone else noticed his blunder. At least you are comfortable enough post to the world just how dumb you can be. Ha Ha. Hope things go better after lunch.
1ton is offline   Reply With Quote
Old 04-04-2021, 12:24 PM   #3
Anteek29
Anteek29's Avatar
LOL...Was I 'Out to Lunch'?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 04-04-2021, 07:30 PM   #4
drolston
drolston's Avatar
I'm glad I never did anything like that!
Old 04-04-2021, 08:26 PM   #5
Habusailor
Habusailor's Avatar
I did almost the same thing with my 35 last spring. Forgot to turn on the battery cutoff saitch, went to the shop to get tools and the charger when i remembered the switch. Stuff happens
Sent from my SM-T550 using Tapatalk
Habusailor is offline   Reply With Quote
Old 04-05-2021, 12:16 PM   #6
mfirth
I know a dumby who put the freshly charged battery back in the car. Went to lunch, came back & nothing happened. Now whats wrong ? Duuuh; never hooked it up........
mfirth is offline   Reply With Quote
Old 04-06-2021, 01:03 AM   #7
Graeme / New Zealand
Graeme / New Zealand's Avatar
"spring fever"
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 04-06-2021, 08:53 AM   #8
tubman
tubman's Avatar
Originally Posted by Graeme / New Zealand View Post
"spring fever"
GB
An astute observation, coming from a guy "down under".
Old 04-06-2021, 01:39 PM   #9
Joe Immler
I have the same problem. My Doctor diagnosed it as CRS Syndrome...Can't Remember Shit !!
Joe Immler is offline   Reply With Quote
Old 04-06-2021, 03:19 PM   #10
Mart
Mart's Avatar
And when you build a fresh engine and put it in the recipient vehicle, don't forget to put some oil in it. Don't ask why I mention this.
Old 04-06-2021, 03:54 PM   #11
Baggs
I’ve a “friend” who routinely makes great double flares when making up brake lines. My “friend “ has routinely tossed the lines after making the length perfect. My “friend “ does forget to put the fitting on the line first.
I still like me though.
Baggs is offline   Reply With Quote
Old 04-06-2021, 04:26 PM   #12
Anteek29
Anteek29's Avatar
Any of you guys changed the oil, then poured in the new oil - without refitting the drain plug first?! I was 16 when that first happened to me...never did it again. My dad was pissed...all over the clean garage floor!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 04-06-2021, 05:33 PM   #13
drezin
Took my newly restored 35 coupe to a car show, parked-got out-walked away about 20 feet- some one yelled your car is on fire. shure enough the whole wiring harness was red hot and burning.grabbed a set of wire cutters and cut most of the wireing harness in two. Stepped back and wondered why I didn't turn the battery disconect switch off under the seat
drezin is offline   Reply With Quote
Old 04-06-2021, 05:51 PM   #14
mfirth
Remember the t v show Hee Haw.....and the song ...If it weren't for bad luck, i'd have no luck at all. Gloom despair.........keep smiling......!
Old 04-06-2021, 10:47 PM   #15
tubman
tubman's Avatar
Please do not go to the H.A.M.B. and check out the thread entitled : "What's the dumbest thing you ever did to your vehicle while working on it?".
Thank you.
Old 04-06-2021, 10:55 PM   #16
Yes Autumn here ( or as you northern folk say "Fall") and getting cooler
GB
Old 04-06-2021, 10:56 PM   #17
or CRAFT disease.
GB
Old 04-06-2021, 11:10 PM   #18
Tinker
Tinker's Avatar
Smoked a original yellow top coil when I had a yblock on the stand. Left the switch on. It happens.
https://www.youtube.com/watch?v=edmqTODMZC4
