Old 08-27-2021, 07:57 AM   #1
Afordman31
Afordman31's Avatar
Default Model A Transmission
What would make a Model A Transmission lock in High Gear?
Afordman31 is offline   Reply With Quote
Old 08-27-2021, 09:46 AM   #2
Charlie Stephens
Default Re: Model A Transmission
If you had it apart you may have missed the groove on the gear when you reinstalled the tower. Any recent work?
Charlie Stephens
Old 08-27-2021, 12:30 PM   #3
Afordman31
Afordman31's Avatar
I had shifted it a few times in all gears and it seemed fine. Then it locked in high after a short run.
Old 08-27-2021, 01:12 PM   #4
Patrick L.
Patrick L.'s Avatar
So, the transmitter has been apart recently ?
Remove the tower and have a look see.
Old 08-27-2021, 01:15 PM   #5
Tom Endy
Tom Endy's Avatar
The half inch round ball on the end of the shifter may be worn square along with wear in the slots of the shifting forks. This can allow the shifter to become disengaged from the forks.
Tom Endy
Tom Endy is online now   Reply With Quote
Old 08-27-2021, 02:15 PM   #6
Brentwood Bob
Is the rivet still in tact, and in place?
Fork can be bent, gap too wide for notch in shifter fork.
Tom endy's write up covers a first class rebuild procedure.
Brentwood Bob is offline   Reply With Quote
Old 08-27-2021, 04:49 PM   #7
Afordman31
Afordman31's Avatar
Will look over these recommendations. Thanks!
