Old 07-14-2014, 08:03 PM   #1
lecktrix
lecktrix's Avatar
Default Engine Stand... I dont see how
Hello all... Im new to the flathead world, and im about to start a rebuild. I know the issue has been discussed tons of times on here... but what should I do... I have seen the exhaust port stands and the front and rear stands. I have two 1948 V8's that I need to tear down. I have done tons of modern motors and I hang them from the bellhousing... I just noticed that part of the bellhousing is the oil pan..
Im definately not comfortable hanging this motor on the top of the bellhousing, and im definately not happy hanging my motor from the exhaust ports...
Am I crazy, or is it safe to suspend a complete motor from the exhaust ports??
lecktrix is offline   Reply With Quote
Old 07-14-2014, 08:10 PM   #2
Fredb_
Fredb_'s Avatar
Default Re: Engine Stand... I dont see how
I made a bracket for the exhaust mount and it worked fine for me on a couple different engines.
Fred
Fredb_ is offline   Reply With Quote
Old 07-14-2014, 08:13 PM   #3
Shadetree
Shadetree's Avatar
I felt the same way but it worked fine. I believe I bought my exhaust port mount from Red's headers. Everyone says absolutely not to use the bell housing as it could break, destroying your block.
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 07-14-2014, 08:17 PM   #4
35fordtn
35fordtn's Avatar
Here is the link to one I used bought off ebay and worked great. http://www.ebay.com/itm/Flathead-For...c73387&vxp=mtr
35fordtn is offline   Reply With Quote
Old 07-14-2014, 08:20 PM   #5
tiquer
Do not hang the motor by the bell houseing alone I have seen a flat motor that was destroyed doing that. It broke a third of the bell houseing away.
tiquer is offline   Reply With Quote
Old 07-14-2014, 08:21 PM   #6
Binx
I find it easier to tear them apart on a sheet of plywood on the floor then build them up on a stand.
Lonnie
Binx is offline   Reply With Quote
Old 07-14-2014, 08:28 PM   #7
deuce_roadster
deuce_roadster's Avatar
The KR Wilson engine stand used by all Ford Service Departments held the engine by the front and rear exhaust ports. That should allay any fear you have about hanging the complete engine by the exhaust ports.
Old 07-14-2014, 08:32 PM   #8
JSeery
JSeery's Avatar
Yep, that is what I was going to say, if it was good enough for Ford, it should be good enough for us! And I can attest to the breaking of the bellhousings, my current block was broken by a previous owner.
Old 07-14-2014, 08:42 PM   #9
4tford
4tford's Avatar
I use the ones that mount on the exhaust ports. Very easy to use and strong as well.
4tford is offline   Reply With Quote
Old 07-14-2014, 09:02 PM   #10
Bassman/NZ
Bassman/NZ's Avatar
I used a bellhousing mounted stand, but I supported the front of the engine with a piece of rope and my engine lifter. I definitely did not feel comfortable with just the stand on its own.
Bassman/NZ is offline   Reply With Quote
Old 07-14-2014, 09:23 PM   #11
ct1932ford
ct1932ford's Avatar
Just getting ready to paint and assemble mine! 4 bolts attached to the top rear bell housing. Make sure all bolts are tight and use large washers. Did the same thing on my roadster with no problems.
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 07-14-2014, 09:40 PM   #12
JSeery
JSeery's Avatar
Works great until it brakes. Lots of people get away with it, some don't.
Old 07-14-2014, 09:55 PM   #13
Ronnie
Ronnie's Avatar
Get walt to show his. It is a plate that bolts to the 59a bell and then the plate is what the engine stand arms bolt to.A very sturdy way to set up an engine on a conventional stand. The chance of the bell breaking that way is all but eliminated.Just a plate would work as well oround 1/2" thick should do it.But then you need to fabricate a new stub end to fit your stand.Walt's way is way simpler to fab up.
R
Ronnie is offline   Reply With Quote
Old 07-15-2014, 01:49 AM   #14
Capn John
Capn John's Avatar
STUMPY'S makes an engine stand that bolts to the exhaust ports!!!
[email protected]
NOTE: The engine stand listed above from ebay is a STUMPYS stand.
"Here is the link to one I used bought off ebay and worked great. http://www.ebay.com/itm/Flathead-For...c73387&vxp=mtr
http://stumpysfabworks.weebly.com/st..._Products.html
Capn John is offline   Reply With Quote
Old 07-15-2014, 02:41 AM   #15
Old Ford Addict
Old Ford Addict's Avatar
I decided and started keeping my eye out for a block a couple months ago.
The very next early block I find that’s un usable is going to prove this entire debate true or faults.
I’m betting the stand bends when I lower the loader bucket on it.
Old Ford Addict is offline   Reply With Quote
Old 07-15-2014, 03:02 AM   #16
BILL WZOREK
BILL WZOREK's Avatar
Think about this Question this way ~~ Of all the Bellhousings that have been broke ask how many were mounted on the engine stand by way of the exaust ports, I think that # may be ZERO
My example is Hanging the engine off the bellhousing is like having Sex with out protection you may get away with it many / many times BUT Sooner or later you will get caught & pay the big price !!!
BILL WZOREK is offline   Reply With Quote
Old 07-15-2014, 09:25 AM   #17
Mart
Mart's Avatar
I made an exhaust port mount that used all six bolts, but it only fits one side. I have used it on the other side a couple of times with just 4 bolts, but prefer to use the 6 when I can. All the evidence shows that just 4 bolts are adequate.
I never use the bellhousing bolts, too many reports of breakages for my liking. No reports of any problem using the FORD APPROVED method of attaching to the exhaust ports.
Mart is online now   Reply With Quote
Old 07-15-2014, 09:37 AM   #18
Ronnie
Ronnie's Avatar
Lots of reports but no pictures.Some forums say "no" pictures is it "didn't" happen.Lets see how many pictures are out there.
R
Old 07-15-2014, 09:57 AM   #19
JSeery
JSeery's Avatar
I have seen a lot of photos posted on this subject and have posted some myself. But I guess the real issue is there is not an engine stand police that I am aware of, so mount the engine anyway you want. There are ample stories on the Barn and elsewhere of people doing this for years and getting away with it. I would think even a quick look at the thickness of the material in the bellhousing area of a 59a block would lead you to see this is probably not a good idea. But again, it is your block do what you want with it, and I'll bet that you will get away with it just fine. My block was broken this way and I'm not taken any chances in the future, but that is just me.
Old 07-15-2014, 10:08 AM   #20
51504bat
51504bat's Avatar
I bought an adapter from Stumpys for my 99t but I sold the motor and only have 8ba's so I no longer need the adapter. PM me if you are interested.
