07-11-2023, 11:37 AM | #1 |
Odd Carb Issue
Hey All,
Suddenly I have a weird carb issue. Yes, I could swap it with one of my spares, but curiosity has a grip on me. The carburetor started leaking about a month ago, ... * Part Time *. Gas smell, and wet outside of carb with a drip (1 drip per 3-5 minutes) leaving the carb from the bottom assembely bolt. Carb is wet below the seam, but does pass the seam at the A/F mixture screw and it's wet there. All bolts and inlets are sealed. It's coming from the weep hole on the bottom of the throat. Float level is at 5/8". If I raise or lower the float level, car either stalles or stumbles at a stop. GAV 1/8 - 1/4 open RPM 400 - 415 Timing at zero with Nu-Rex automatic timing gizmo Odd thing is, if I blow a 1/2 second quick shot of air into the throat of the carburetor, leaking stops. Any ideas? Regards Bill |
07-11-2023, 01:50 PM | #2 |
Re: Odd Carb Issue
