06-30-2010, 08:34 PM | #1 |
weber carb
is anyone running the weber carb and manifold they sell at mikes or brattons? if so do you like it? have pictures of it on the engine? iam thinking of new carbs but cant decide which way to go thanks
06-30-2010, 09:23 PM | #2 |
Re: weber carb
I run one. The only difference from a Tilly is that you've got a lot more pedal at 45mph.
06-30-2010, 10:01 PM | #3 |
Re: weber carb
Ive got one sitting on the engine on the stand, but havent tried it out yet. Everyone i know that has one, LOVES them. No they arent the prettiest thing ever, but they work really good. I bought the reproduction original style exhaust manifold from snyders and both manifolds matched up nicely. Another option that alot of people run is either the cast iron performance manifold or the tube headers. The weber is in my opinion probably the best 2 barrel carb you can put on the model a. It only uses one barrel in the city, or at cruizing speed. Then once you punch it, it opens the second barrel which is significantly larger throat size. So your going to get pretty good gas milage, and you will see a performance up grade.
Cowtown A's |
07-01-2010, 06:53 AM | #4 |
Re: weber carb
I am going to get one. Piranios dyno shows 18% peak hp gain on stock engine.Arizona Model A sells the kit with the carb jetted for the A. He also sells the correct low pressure fuel pump. Phone 480-782-0226
07-01-2010, 08:17 AM | #5 |
Re: weber carb
We installed our first Weber on a Model A about 7 years ago. We got better gas mileage and performance. In the Fall 2009 issue of the Model A Times we wrote up installing one in the roadster using a 6V fuel pump there are pictures on the installation there. We have one on the sedan that went to Texas a couple of years ago so you can see we are big fans. The last one we bought from Arizona Model A parts 480-782-0226
07-01-2010, 03:20 PM | #6 |
Re: weber carb
07-01-2010, 03:24 PM | #7 |
Re: weber carb
i would like to trade 2 97's / zepher manifold for one with intake for a header .. thank you .. steve
V4f |
07-01-2010, 03:36 PM | #8 |
Re: weber carb
I tried one, and it did have noticeably more power at high rpm, but I never could figure out how to start the engine quickly, and I didn't like the fuel pump plumbing and wiring. Also, I'd ask how it performs in cold weather without manifold heating.
07-01-2010, 05:35 PM | #9 | |
Re: weber carb
So it made 47.2 HP on the dyno?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
07-01-2010, 05:56 PM | #10 |
Re: weber carb
07-01-2010, 06:02 PM | #11 |
Re: weber carb
Steve Norcal, not sure exactly what you want. I have a good Zepher aluminum intake with a single model 94 carb and linkage and three spare 94 carbs if that is what you want I would trade. Thanks, Purdy.
07-01-2010, 07:03 PM | #12 |
Re: weber carb
I’m using this weber carb setup for some time and found it to be very reliable using a low pressure carter electric pump. My pump is mounted inside the frame and kind out of sight under an aluminum shield and is very quiet. It’s not hard to start you just really choke it and it just takes off. Power and mileage is very good about 20 MPG touring with some hills.
Mike |
07-01-2010, 07:41 PM | #13 | |
Re: weber carb
Cowtown A's |
07-02-2010, 12:27 PM | #14 |
Re: weber carb
Logan
I made a shield just for the summer time but it’s really not needed so I just leave it in place. The weber needs some kind of hot air intake to keep from getting to cold so some year I’ll make up something. Mike |
07-02-2010, 01:38 PM | #15 | |
Weber carb vs. other options
Regarding a Weber carb...I recently supplied an engine that was fitted with a Weber along with a few other mods. The engine produced a bit over 62hp on Bill Stipe's dyno. You can study the dyno report if you are interested. See the dyno report at: www.durableperformance.net The Dyno Report link is located on my Pricing page directly below the Touring Engine info. Just "click" on the DYNO REPORT link to view. Good Day! Dave in MN |
07-02-2010, 01:56 PM | #16 | |
Re: weber carb
How did you wire the fuel pump? Does it run whenever the ignition is on, or is there a switch? I have a master electrical cut-off switch. Should I connect it to the master so it runs a couple of seconds before starting? Thanks. |
07-02-2010, 02:06 PM | #17 |
Re: Weber carb vs. other options
Thanks Dave, Good luck with the dual B carb updraft. I really like mine. I can really feel the power in the speedster when it reaches the rpm for the high speed jets to cut in. I had to put a spring on the choke of the back carb or it would draw the choke closed if I gave it full throttle.
07-02-2010, 08:27 PM | #18 |
Re: weber carb
To: Michael in Sedona,
My Model A has a 12 negative ground system. The fuel pump connects to the ignition switch the same as for the coil but has its own fuse. No need for a separate fuel pump switch or priming before starting but all cars should have a master switch also. The Weber will run from tanks gravity feed but will starve out driving. I found the best pump is a Carter P60504 low pressure its quiet and is available 6 or 12 volts pos or negative setup. Mike Ovale |
07-02-2010, 11:02 PM | #19 | |
Re: weber carb
07-03-2010, 07:29 AM | #20 |
Re: weber carb
If your running an electric fuel pump don't forget to install an inertia switch to shut off the pump incase of an accident. Late model Fords used them to shut off the pumps on fuel injected cars. I wired mine to not only shut off the fuel but also a solenoid valve in the fuel line.
