Old 10-02-2019, 09:02 PM   #1
Big Shark
Big Shark's Avatar
Default 37 glove box clips
Looking for instructions on installing the spring clips that hold the glove box door shut. I had them hooked but the door wouldnt stay closed. Thanks Bruce
Big Shark is offline   Reply With Quote
Old 10-03-2019, 12:20 AM   #2
RalphM
RalphM's Avatar
Default Re: 37 glove box clips
Not sure on 37, but 36 has to go all the way behind door hinge hold down.
File Type: jpg 394B287E-3410-433D-B8B8-0B58F3492FEE.jpg (51.2 KB, 89 views)
RalphM is offline   Reply With Quote
Old 10-03-2019, 03:58 AM   #3
cajunfirehawk
cajunfirehawk's Avatar
Good luck, just did my 36, no fun involved, lol
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 10-04-2019, 07:44 PM   #4
Gary Tosel
Gary Tosel's Avatar
I do not know about the 37 Ford glove box, but the 36 Ford glove box door can be installed fairly easily.
Place the door and the hinge plate inside the box. Install the bottom screws with acorn nuts (note previous photo showed screw ends inside the box, which I believe is not correct) inside the box loose as possible.
Then with someone holding the glove box door, install the springs on each end of the door with the door closed as much as possible. Then tighten the screws into the acorn nuts and the door should then be able to be closed and stay closed.
Hope it works for you like it did for me.
Gary Tosel is offline   Reply With Quote
Old 10-06-2019, 07:27 PM   #5
v8fordman
v8fordman's Avatar
Are you using reproduction springs? If so, that may be your problem.
v8fordman is offline   Reply With Quote
Old 10-06-2019, 08:57 PM   #6
Big Shark
Big Shark's Avatar
Yes they are repop springs
Old 10-07-2019, 08:31 AM   #7
RalphM
RalphM's Avatar
If you will notice in the picture I have one original and one reproduction spring. Not an issue, they both sit about the same.
Old 10-07-2019, 11:54 AM   #8
Fullfendered
Fullfendered's Avatar
37 pictures
Fullfendered is offline   Reply With Quote
Old 10-08-2019, 06:54 AM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
If those springs are not hooked in the correct position on door and hinge plate, you will have trouble. Once I learned the correct way to do those on 35 & 36's, it became a very simple procedure.
John
Old 10-11-2019, 09:18 AM   #10
Big Shark
Big Shark's Avatar
Figured it out. Thanks
