Old 08-19-2019, 08:48 PM   #1
Big Shark
Big Shark's Avatar
Default 37 wiring issue
Hi Guys, I'm installing a wiring harness in my car. The issue is, the wiring from the headlights are R/BLK, Y/BLK and G/BLK. The wires from the harness are, WHITE/R, WHITE/G, and BLK/YELLOW. Anyone have any ideas. The harness is a "Wirey Joe" replacement. Thanks Bruce
Big Shark is offline   Reply With Quote
Old 08-19-2019, 08:57 PM   #2
JSeery
JSeery's Avatar
Default Re: 37 wiring issue
Well, a wild guess would be red to red, green to green & yellow to yellow. Can you trace the wires out and connect them by function?
Old 08-19-2019, 10:28 PM   #3
Tinker
Tinker's Avatar
http://www.vanpeltsales.com/FH_web/F...wiring1937.jpg
Might need to get a meter out.
Old 08-19-2019, 10:46 PM   #4
einstein
Colors don't mean anything Use a test light to find out what works then connect your new wires to it .I just rewired my 40 and used my own wires , just mark them as you connect them
einstein is offline   Reply With Quote
Old 08-19-2019, 10:50 PM   #5
Tinker
Tinker's Avatar
Gratuitous wiring source.
Sacramento Ford. rewired a few cars. always happy with their stock harnesses. eazy-peesy.
Old 08-19-2019, 11:46 PM   #6
1937sedandelivery
Given this situation, I would:
turn the steering column light switch to the parking light position, then touch each wire from the main harness to each of the light harness wires. One of the connections should light up the parking light. Keep that connection. Next, turn the light switch to the low beam position. Do the same procedure with the other two connections. Keep the connection that lights up the low beam headlight. The last connection is easy, it is the only one left, make that connection and voila!
gregg
1937sedandelivery is offline   Reply With Quote
Old 08-20-2019, 01:02 PM   #7
supereal
supereal's Avatar
Many replacement wiring looms contain unused wires so they can be used on several makes and models. When you order, ask if there is a diagram included. If not, look elsewhere.
supereal is offline   Reply With Quote
Old 08-21-2019, 02:39 PM   #8
DavidG
DavidG's Avatar
"Colors don't mean anything...."? With original harnesses and quality model-specific reproductions they are the beginning and ending of the job.
Old 08-24-2019, 07:15 PM   #9
Big Shark
Big Shark's Avatar
Why would the solenoid arc to the firewall. If I remove the two screws, it starts fine. Any suggestions? Thanks Bruce
Old 08-24-2019, 09:17 PM   #10
JSeery
JSeery's Avatar
Do you know which solenoid type you have? There are a number of them, some are grounded and some are not. But none of them should ground the battery connection to ground. It is also possible it is defective.
How about posting a drawing of how you have it wired up?
Old 08-26-2019, 05:37 AM   #11
Big Shark
Big Shark's Avatar
It is the original solenoid, with the starter button on the bottom
Old 08-26-2019, 06:42 AM   #12
JSeery
JSeery's Avatar
And the starter button on the dash is a ground?
Old 08-26-2019, 08:45 PM   #13
Big Shark
Big Shark's Avatar
Bad solenoid!!!!!!! Have a new replacement, No more arcing. Now I have to get back to the wiring harness. Thanks for your input. Bruce
