Old 07-05-2018, 09:31 PM   #1
junkyardjeff
Default Window regulator roller repair
Working on a friends 58 Edsel convertible with power windows and the right rear dropped down,after some investigation the stud on the regulator where the roller attaches broke. New rollers are available but I was hoping to find a repair kit for that stud but I have not found any and since it has power windows that regulator might be hard to find and not looking forward to replacing it. Anybody ever have this problem and what did you do but I think its time for some yankee enginuity with a bolt and nut.
junkyardjeff is offline   Reply With Quote
Old 07-06-2018, 02:17 PM   #2
KULTULZ
KULTULZ's Avatar
Default Re: Window regulator roller repair
You might call a local glass shop and see if they know of anything to repair it.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-06-2018, 02:23 PM   #3
dmsfrr
dmsfrr's Avatar
There's a couple other Edsel owners on here who might be able to help. They may notice this thread sooner if you can go back and edit the title to include the word - Edsel.
dmsfrr is offline   Reply With Quote
Old 07-06-2018, 02:48 PM   #4
Lanny
Lanny's Avatar
Have you looked in the bottom of the door with a good bright light,
and maybe use one of those long skinny mechanics magnets to snag
the broken stud, if it is lodged in the lower front or rear of the door.
You should be able to weld the stud back into the regulator arm.
Also, many FoMoCo cars and pickups of that era used the same
little plastic rollers, so if you can find an old regulator and remove
a stud and weld it in your regulator.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 07-06-2018, 09:30 PM   #5
paul2748
paul2748's Avatar
Lanny is probably right because there is no place for it go when it broke except for the bottom of the door.
If you can't find, more than likely that the stud was the same throughout the Ford Line. Do you have the regulator out? In the 50's Fords that I have worked with there usually are two studs so you should have one to go by for a sample.
If you have a sample, a machine shop might be able to make a new one.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-07-2018, 03:38 AM   #6
KULTULZ
KULTULZ's Avatar
Post Re: Window regulator roller repair
Watch this-
- https://www.youtube.com/watch?v=xF1rok1yN9s
Hopefully they will have a kit for the 58 EDSEL (FORD - MERC)
- WHY IS IT ... -
Old 07-07-2018, 11:25 AM   #7
Lanny
Lanny's Avatar
Jeff, does that Edsel regulator have the removable nylon roller on the stud ?
Or is it the kind in the video, with the nylon roller cast onto the stud ?
I thought '58s had the removable nylon roller...
Old 07-07-2018, 01:10 PM   #8
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Have used a bolt modified into a stud for repairs in the past on similar problems.
streetdreams is offline   Reply With Quote
Old 07-07-2018, 04:46 PM   #9
KULTULZ
KULTULZ's Avatar
The reason I posted that video is to show there are aftermarket repair kits available.
Of course you would have to source the correct kit for your particular application.
There were two series of the 1958 EDSEL, one based on the FORD platform and the other MERCURY.
- WHY IS IT ... -
Thread Tools
Display Modes
