Old 05-01-2017, 03:44 PM   #21
wrndln
Default Re: Floorboard question
Gunmetal blue2,
Does your Aug 29 AA have the straight cut battery hole or the angled type like later floorboards? You mentioned above it is like Iverson's, but I would sure think it would be the wider angled style. Your AA truck is near the vintage of my 29 CCPU, so that is why I am interested in what you have. I assume your floorboard is original, correct? Would you post a picture of you lower floorboard?
Rusty Nelson
Old 05-01-2017, 04:14 PM   #22
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
made by Murray and fits perfect
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 05-01-2017, 04:17 PM   #23
msmaron
msmaron's Avatar
Another Shot
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-01-2017, 04:26 PM   #24
wrndln
Mark,
Your floorboards sure look like they are made from soft wood (fir/pine/spruce) plywood from looking at the grain. Maybe I am wrong and they are made from hardwood plywood. Did you ever measure the thickness of the Murray Linker floorboards?
Rusty Nelson
Old 05-01-2017, 04:38 PM   #25
Larry Jenkins
Originally Posted by Dick Steinkamp View Post
3/4" plywood is actually 23/32
https://www.thespruce.com/identifyin...-sizes-3536691
Only 1/32 (.03) over 11/16. Still too thick?
Some places still offer the full 3'4". Pricey. "X" grades.
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 05-01-2017, 06:29 PM   #26
Charles Reese
Charles Reese's Avatar
not my vintage but wanted to share pic of what i believe are original boards (brake to side). note that the width varys along the length of some boards. one can never have enough pictures
Charles Reese is offline   Reply With Quote
Old 05-01-2017, 08:45 PM   #27
Tom Wesenberg
Tom Wesenberg's Avatar
My original early 29 Tudor boards are the same. The boards vary in width from one end to the other end of each board. This really shows how every possible piece of wood was used by Ford.
Old 05-01-2017, 10:21 PM   #28
Steve Plucker
Same on this end with my Feb. 1929 Tudor.
Pluck
Old 05-01-2017, 11:03 PM   #29
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by Joe K View Post
Deleted - I see well covered in last nights entry after I went to bed - and revealed on today's "refresh."
Good to see looking at an "original" board that Ford used the Linderman construction to achieve "use of scraps." And not just three whole boards as shown on the HTRYMA Vol 6.
The top view of the lower board seems to be made of three boards - not so the bottom of the bottom board which reveals that each of these three segment are made up of as many as three smaller boards. .
Linderman was their version of finger joints.
And does kind of make one wonder again the popular misconception of frugal Henry having used subcontractor supply boxes (and specifying box materials and size along with the engineering specification of the components contained therein) to make flooring for the Model A.
I think we've been through and discredited the legend. But seeing the actual board one wonders.
Joe K
While taking the wood out of a Victoria we found several pieces that were put together from multiple boards using long dovetail joints, while the drawings only showed a single piece.
Old 05-02-2017, 02:31 AM   #30
Tom Wesenberg
Mike, was this floorboards?
If not floorboards, was it dovetailed, or finger joints?
Old 05-02-2017, 04:20 AM   #31
Mike V. Florida
Two layers of dove tail joints. It looked like they were used to create a single board and the cut to size. There was one on the body sill and another on the top side rail.
Old 05-02-2017, 06:49 AM   #32
Joe K
Joe K's Avatar
Lower (foot) board: Looking at denniskliesen's pix it seems that linderman was used to make up the three MAJOR boards as shown in the Ford drawings (and HTRYMA Vol 6/Steve Watrous dwgs.)
These major boards seem to be made of up to three sub-sections, all jointed using linderman too?
Its like Ford put someone to a pile of scraps and said: "Here, use the linderman machine and make planks x by y so we can use that to make floorboards.
I wonder if these sub-sections have any "butt-joints"? Which might have been finger joints (although these were not common until after WWII) or butt joint end grain to end grain (a source of floorboard leak?) or use of the linderman machine (which would give a good joint but one would have to "plan out" his assembly sequence.)
Looking at the actual joint in denniskliesen's pix, I would guess the dovetail to be 5/16" at the wide of the key?
I have the technology to do these boards - and correct size cutters are available from freud and others.
And I just happen to need the lower board for my March 29 CC pickup.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 05-02-2017, 09:53 AM   #33
Tom Wesenberg
I'm also duplicating 3 sets of the floorboards with the dovetailed joints for my 28 Phaeton and Feb 29 Tudor. I finally found the correct router bit at a new and used tool store. It sure takes time to make them, but I like things to be as correct as possible.
Old 05-02-2017, 11:22 AM   #34
denniskliesen
denniskliesen's Avatar
Joe K I'll try to remember to hold a steel ruler up to the end the next time I have them out. They were a perfect fit when I put them back in. I got the welt from Bratton's and new tacks came with it in a bag which I didn't use as I felt they were too big in diameter and length and I didn't want to take a chance splitting them. So I used the old ones.
denniskliesen is offline   Reply With Quote
Old 01-11-2022, 06:41 PM   #35
Dkrahn
Dennis...I do like the pictures. The way it looks to me, for '29 pickup ,the floorboard looks identical to your pictures. I would say the way the pieces are installed are in this order:
1. two wood pieces
2. Metal plate for shifter
3. felt around clutch and brake pedals
4. Metal piece around those pedals
5. Shift Boot on top of wood
6. Then rubber mat
Does that sound accurate?? Appreciate your help..
Dkrahn is offline   Reply With Quote
Old 01-13-2022, 05:37 PM   #36
burner31
burner31's Avatar
I made my own out of marine board, have you considered doing it yourself?
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 01-21-2022, 04:33 PM   #37
hazelhoff
hazelhoff's Avatar
It’s been my understanding Ford pushed their suppliers to deliver their product in oak crates, to enable Ford to make floorboards out of it !
You don’t own a Model A ... it owns you !
hazelhoff is offline   Reply With Quote
Old 01-21-2022, 08:51 PM   #38
Conaway2
Conaway2's Avatar
Does anyone make original style floorboards with multiple pieces of wood and steel straps ?
Thanks - Jim
Conaway2 is offline   Reply With Quote
Old 01-23-2022, 10:09 AM   #39
old ugly
old ugly's Avatar
i really like this post, thanks!
i don't like plywood in early cars because it just wasn't commercially produced until the late 1920s and most manufactures used solid wood board or laminated specially for their own cars.
the edge dovetailed boards are cool, i am going to make a set, someday.
thanks
ou
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
