04-08-2016, 07:35 PM | #1 |
Floorboard question
I am looking for a set of plywood floorboards for my mid 29 pickup, that has a front mounted emergency brake handle. Original planked and plywood floorboards were made of 11/16" thick material. Many vendors sell floorboards made of 3/4" plywood, which is too thick, especially once the edging is tacked in place. Ahooga Reproductions sells plywood floorboards that are made of 11/16" plywood, which is the correct thickness, however I question their mid 29 lower floorboard battery cutout and the shift tower cutout. The link to their mid 29 floorboard (front mounter emergency brake) is pasted in below. I made the planked floorboards for my 28 special coupe and early 29 phaeton using Steve Watrous drawings. Other than a coupe minor dimensional problems, the two sets of floorboards turned out well. Anyway, I know the 1928 lower floorboards had an inline narrow battery cutout. The first drawing attached is Steve's drawing I used to make my 1928 lower floorboards. The second floorboard drawing attached is Steve's later floorboard drawing used for the side mounted emergency brake. My question is: It seems like the early to mid 1929 floorboards should have the cutout around the shift tower and emergency brake just like the 1928 floorboards. The battery access hole I would think would be wider and at an angle like the second drawing. Steve doesn't have a drawing for the early to mid 1929 lower floorboards, which is unfortunate. If anyone knows what a mid 29 lower floorboard looks like, before the side mounted emergency brake was used, please post a picture or information about it.
Thanks, Rusty Nelson http://www.ebay.com/itm/A2829-FB-192...9XB~kG&vxp=mtr |
04-09-2016, 11:59 AM | #2 |
Re: Floorboard question
Good question Rusty! And yes, there could/should be another..?
04-09-2016, 01:01 PM | #3 |
have any carpenter friends with a big plainer?
04-09-2016, 05:11 PM | #4 |
Rusty why not just call Murry Linker and have him make you a perfect set???
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
04-12-2016, 12:17 PM | #5 |
I have an April 1929 blind back 4 door with original solid oak floor boards, mounted to the steel straps. If you have had no response I can measure and take photos.
04-12-2016, 02:57 PM | #6 |
04-12-2016, 03:58 PM | #7 |
4port,
Briggs and Murray floorboards might be different from Ford bodies as they have wood subrails unlike Ford made mostly steel bodies/subrails. The things I am trying to figure out is when the wider angled battery hole was implemented and the shape of the cutout for the gear shift tower and front mounted emergency brake. If you could take a picture of your front lower floorboard, that might help me understand what a mid 29 floorboard looks like even though your car isn't exactly like Ford body. What month was your car made? Thanks for the response. Rusty Nelson |
04-30-2017, 07:39 PM | #8 |
Did you ever find the floorboards you needed?
Ahooga also has the 29 floorboards with the straight battery cutout also. Just give them a call, and I'm sure they can send you a picture. I know that they currently have a few of these in stock. |
04-30-2017, 08:25 PM | #9 |
The floorboard I need is like the one in the picture - FB2 C. All the floorboards I have seen at vendors are like FB2 A, FB2 B or FB2 D in the picture below. The FB2 C floorboard was only used, according to the Restorer article (Mar/Apr 1995), for about 4 or 5 months until the side mounted emergency brake was introduced in July 29. I think that is why the vendors don't carry it.
BTW, I talked to Murray Linker two or three years ago and I am pretty sure he said his plywood floorboards were made out of 3/4" plywood, not 11/16" plywood. I could be mistaken, but I don't think so. Rusty Nelson |
04-30-2017, 08:34 PM | #10 |
Hey Rusty, if they did use that until July 29, I have a July 28 that has the E-brake in front of the shifter AND that same floorboard, so that would make it used for a full year while the front E-brake was used.
Just my 2 pennies |
04-30-2017, 09:11 PM | #11 |
The difference would be that the floorboards were made up of several dovetailed boards until the change to plywood in early 29.
04-30-2017, 10:26 PM | #12 |
I think Neil Wilson did a well researched article in The Double A'er about floor boards...You might want to see if you can get that article. I think it was in the 2007 issue and may have another.
Pluck |
04-30-2017, 10:38 PM | #13 |
To clarify, the FB2 B was used until March 1929. The FB2-B floorboard was, like Tom W indicated, made of dovetailed hardwood only, not plywood until March 1929. The FB2-B floorboard had the narrow straight battery cutout, not the wider slanted battery cutout. Ford continued to used dovetailed hardwood & started using plywood in March/April 1929. Ford used dovetail hardwood floorboards through out model A production, but most were plywood as time progressed. This is information in the Restorer article (see attached page from the article).
Rusty Nelson |
04-30-2017, 10:42 PM | #14 | |
https://www.thespruce.com/identifyin...-sizes-3536691 Only 1/32 (.03) over 11/16. Still too thick?
All steel from pedal to wheel |
04-30-2017, 10:46 PM | #15 |
This is the first time I've heard of the dovetailed floorboards being used to the end of production.
I wonder if anyone has these in a later original car or truck? |
04-30-2017, 10:59 PM | #16 | |
The guidelines also call out the mid-year covers the months, May, June, July, and August."
04-30-2017, 11:33 PM | #17 |
Here are some photos of hardwood original floorboards in a January 29 Tudor. These are front boards. I started to post and lost the page because it took me too long to find my pictures in photobucket. Edited: Measured with a dial caliper thickness is .685" at the battery inspection hole currently after lightly sanding only a minimum of nonoriginal paint and repainted black. There might be some shrinkage after 88 years.
05-01-2017, 06:25 AM | #18 |
Deleted - I see well covered in last nights entry after I went to bed - and revealed on today's "refresh."
Good to see looking at an "original" board that Ford used the Linderman construction to achieve "use of scraps." And not just three whole boards as shown on the HTRYMA Vol 6. The top view of the lower board seems to be made of three boards - not so the bottom of the bottom board which reveals that each of these three segment are made up of as many as three smaller boards. . Linderman was their version of finger joints. And does kind of make one wonder again the popular misconception of frugal Henry having used subcontractor supply boxes (and specifying box materials and size along with the engineering specification of the components contained therein) to make flooring for the Model A. I think we've been through and discredited the legend. But seeing the actual board one wonders. Joe K
Shudda kept the horse. Last edited by Joe K; 05-01-2017 at 06:43 AM. |
05-01-2017, 03:03 PM | #19 |
Pics of our 6-21-28 touring boards not plywood
05-01-2017, 03:21 PM | #20 |
my 29 AA made 8-30-29 had hard wood floor board on the bottom and it had the straight and rounded metal strapes. looks like iverson floor board.
