Old 01-16-2022, 05:39 PM   #1
[email protected]
Default removing the pinion race, how
Any good ideas on removing double race from the pumpkin. thanks, steve
steveankc@gmail.com is offline   Reply With Quote
Old 01-16-2022, 05:51 PM   #2
Synchro909
Synchro909's Avatar
Default Re: removing the pinion race, how
Rather expensive but this would do the job. Many people make their own similar device.
https://www.snydersantiqueauto.com/p...8119&cat=41753
Old 01-16-2022, 06:46 PM   #3
quickchange
quickchange's Avatar
If replacing it , Just run a weld around the inside & that shrinks it , will fall out,
quickchange is offline   Reply With Quote
Old 01-16-2022, 07:41 PM   #4
chrs1961815
chrs1961815's Avatar
You can either pound out carefully while it is well supported or for the novice you could heat the area up and it should pretty much fall out.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 01-16-2022, 07:48 PM   #5
larrys40
Steven
I use kr Wilson puller meant for the task Aata-1 . Works awesome but I realize they are far and few between.
I would suggest if there is someone in a nearby Model A club who might have something. You can also call Mitchell who does the overdrives and see what their cost is for theirs.
Where are you located. Pot that so possibly someone nearby who might have for in access can help.
Larry Shepard
larrys40 is offline   Reply With Quote
Old 01-16-2022, 08:35 PM   #6
Tom Endy
Tom Endy's Avatar
I have tool I made from an old, failed pinion gear that was on the end of a drive shaft. I cut the shaft down to about ten inches long. The pinion gear has the old bearing on it. In order to pull the race out of an otherwise empty banjo I insert the tool and attach my pinion puller to it and the pinion bearing will pull the race out.
Tom Endy
Tom Endy is online now   Reply With Quote
Old 01-16-2022, 09:24 PM   #7
Conaway2
Conaway2's Avatar
I bought one of these and have used it several times - it works quite well for axle housing and pinion races.
Jim
https://www.brattons.com/REAR-AXLE-H...ductinfo/6091/
Conaway2 is offline   Reply With Quote
Old 01-17-2022, 12:36 AM   #8
jw hash
jw hash's Avatar
if you have a welder, Quickchange is right on.
jw hash is online now   Reply With Quote
Old 01-17-2022, 05:42 AM   #9
Bruce of MN
Bruce of MN's Avatar
Does this show removing the bearings that you mean?
https://www.brattons.com/media/wysiw...r-Apr-2012.pdf
Old 01-17-2022, 02:28 PM   #10
[email protected]
well used a torch, heated it good ,and hammered it out. thanks, steve
Old 01-17-2022, 07:25 PM   #11
Rodrelic
Made one using a fabbed piece that had chain and bottle jack involved. Got it out 1 piece
Rodrelic is offline   Reply With Quote
Old 01-17-2022, 11:13 PM   #12
daren007
Welder
daren007 is offline   Reply With Quote
Old 01-18-2022, 02:52 PM   #13
gdmn852
gdmn852's Avatar
Hello,also note IF any shims are between race and pinion housing,some were shimmed to get correct gear tooth setting.
gdmn852 is offline   Reply With Quote
Old 01-18-2022, 04:56 PM   #14
larrys40
With all due respect this is NOT true . Trying to make sure original poster has good information if a rebuild is necessary. Like Tom Endy, Ive done hundreds of rear axles and have never had a pinion race shimmed. I don’t believe there is any original ford shim part number either. Gear depth pinion to ring gear is accomplished with gasket thickness left to right housing after total carrier preload is determined. I think Toms is probably the best on line article out there and there are others in printed form.
They are not enormously difficult to do but there is a process that if done right will give you an reliable axle for many miles to come.
Getting back to the original posters issue, please update us when you know what the culprit was.
Happy Model A motoring.
Larry Shepard
Old 01-18-2022, 05:19 PM   #15
old ugly
old ugly's Avatar
there are two types of car pinions one early style does not have a pinion carrier.
later has the pinion carrier.
the early style needs to be removed from the housing before it can come off of the driveshaft. the drive shaft/pinion assy will not come out of the banjo as an assy.
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 01-20-2022, 07:41 AM   #16
Bob Bidonde
Bob Bidonde's Avatar
The pinion race tools are nice if one is rebuilding many differentials. However, if just one or two, welding the ID of the race / heating the exterior of the housing works fine.
Bob Bidonde
Old 01-20-2022, 08:43 AM   #17
Bruce of MN
When I installed my Mitchell OD, I used my club’s pinion puller.
