Old 03-20-2018, 01:10 AM   #21
KULTULZ
KULTULZ's Avatar
Exclamation Re: PCV systems on the smallblocks
Originally Posted by estout81 View Post
The 5.0 EFI had the PCV in about the same place on the manifold.
Yeah it did come to think of it.
THANX for the memory jog...
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 03-26-2018, 04:48 PM   #22
willowbilly3
Default Re: PCV systems on the smallblocks
You can't really see the pcv, it is off the 2 big vac ports and Teed. 5.0 efi intake modified to use twin .98 2100s on my 260.
willowbilly3 is offline   Reply With Quote
Old 03-30-2018, 10:34 AM   #23
5851a
It wasn't the best system in cold climates. There was a mesh screen under it and short drives in sub zero would freeze it into a block of ice. Blowby would start oil leaking from all the gaskets and seals.
5851a is offline   Reply With Quote
Old 04-08-2018, 11:08 AM   #24
KULTULZ
KULTULZ's Avatar
Red face Re: PCV systems on the smallblocks
I just wish I could post more info but am waiting for printer ink.
FORD actually first offered PCV in the 1960 model year, a model year earlier than the CA requirement. As for the 292, it had to comply with differing area emission law(s) so it was fitted with PCV. That is why it is so confusing as the engines were built/calibrated for where the vehicle was to be sold.
Either FORD had to bring the 292 into compliance or was not allowed to sell the 292 equipped vehicle in CA for instance.
Well...
Finally got the cartridges but FIREFOX updated my browser and I cannot communicate with the printer.
As soon as I join the living again, I will show the drawing.
ADDENDUM-
SHELBY COBRA TIGER
- WHY IS IT ... -
Old 04-11-2018, 02:36 AM   #25
KULTULZ
KULTULZ's Avatar
Finally...
The setup is for both 2V and 4V.
- WHY IS IT ... -
Old 04-11-2018, 07:15 AM   #26
junkyardjeff
It looks like I will have to go back and get that filter and retainer.
junkyardjeff is offline   Reply With Quote
Old 04-11-2018, 08:32 AM   #27
KULTULZ
KULTULZ's Avatar
Thumbs up Re: PCV systems on the smallblocks
Yeah, that is the actual oil/vapor separator and is necessary. It is replaced on a scheduled basis.
C2OZ 6A631-A - FA-58
Gasket PN- C2OZ 6870-A (FEL-PRO should have it)
Valve PN- C1AZ 6A666-A
- WHY IS IT ... -
Old 11-27-2020, 12:59 AM   #28
PetesPonies
PetesPonies's Avatar
Road draft was absolutely used in the 1965 model year. Absolutely.
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
Old 11-27-2020, 09:09 PM   #29
junkyardjeff
When and if this all goes togather I have a 66 4 bbl intake that has the provision and the three threaded holes for that PCV system but the larger hole is not drilled so it will have to be machined.
Old 11-27-2020, 11:15 PM   #30
PetesPonies
They were delivered different ways. Some had a plug in the hole. Some had nothing but a flat place where it went. Some had the threaded holes for fasteners, but no opening for the gases.
Pete's Ponies
Old 11-28-2020, 08:19 AM   #31
KULTULZ
KULTULZ's Avatar
Post Re: PCV systems on the smallblocks
Now we are talking 5.0L EFI correct? Was your 5.0L HO, STD or LT? How far north were you when the system froze?
Now for the earlier road draft design.
Two SBF tubes shown below, one manifold mount and the other rocker cover mount (1965) -
- WHY IS IT ... -
Old 11-28-2020, 11:25 AM   #32
PetesPonies
Yep, correct
Pete's Ponies
Old 11-28-2020, 02:19 PM   #33
junkyardjeff
The PCV on the EFI is a pain to get to.
