06-03-2015, 11:24 AM | #1 |
36 or 37 deluxe 5 window coupe
Hello again thanks for all you guys help
wondering if in '36 if Ford would have put a '37 flat head in my '36 5 window coupe? the rear windows have 3-36 on the Ford emblem but i'm not sure when the body met the frame. Is it possible that the '37 flat head was stock in late '36? Kevin |
06-03-2015, 11:26 AM | #2 |
Re: 36 or 37 deluxe 5 window coupe
Pretty sure back in the day ford would replace an engine rather than fix. So one possibility was instead of a major repair they took new one off shelf.
Thanks - 30-9 1939, 1940 |
06-03-2015, 11:27 AM | #3 |
It's MORE likely that a defective '36-type engine was replaced possibly early-on by a '37-type engine. DD
06-03-2015, 11:30 AM | #4 |
