08-27-2020, 02:29 PM | #1 |
34 rear hub bolts
I need some rear hub bolts fo my 34 . My local supplier has sent me bolts listed as suitable for1928 to 1935 , they are approx 1/4 shorter than my originals ( 1 5/8 ) . I have checked online with other suppliers , they list the same . Are the correct length bolts available ?
08-27-2020, 03:16 PM | #2 |
Re: 34 rear hub bolts
Used ones should work fine and they would be originally correct. Have you checked with the NOS guys here on the Barn?
08-29-2020, 10:51 AM | #3 |
I'm having the same trouble. The correct Ford part number is "B 1118".
The generic hub bolts being manufactured and sold today aren't even good for the front hubs; "B 1107"....their too long in the shank requiring them to be machined down in order to have the correct height when swaging them into the hub. I DID find a suitable alternative for my front hub bolts. The Model T rear hub bolts (part #T 2888) that are being made today fit well for the original front 33/34 hubs, their just a thread too short in overall length, but can be swaged in like the originals. |
09-03-2020, 07:38 PM | #4 |
Thanks for your replies, have reused some good ones.used Locktite to hold them because the shoulder had been removed to get them out . Will try and obtain some nos B1118 or 48 1118 . Lead foot thanks for the tip on the front bolts
09-04-2020, 12:39 PM | #5 |
