06-04-2021, 02:36 PM | #1 |
My '53 Customline
Some pictures of my Customline.
Got it inspected and titled here in Sweden a few days ago and this evening I made the first longer testdrive, about 20 miles. It's running great, oil pressure is good and it doesn't overheat. Not bad I think for a car thats been sitting in a shed in California for the last 30 + years. |
06-04-2021, 03:24 PM | #2 |
Re: My '53 Customline
Looks and sounds good !! When did you get it in Ca. and how did you ship it??
06-04-2021, 03:38 PM | #3 |
Thank you.
Bought it in December 2020 and it arrived here in March. Got it inspected by a Swedish guy who lives in Sacramento and he arranged the whole shipping with West Coast Shipping. He's also the one who found it for sale on Craigslist for me. |
06-04-2021, 03:40 PM | #4 |
A picture from the shed where it's been sitting since 89-90.
And one from when it arrived at my garage in March. |
06-04-2021, 03:44 PM | #5 |
Result! Happy days ahead for you Mikko. Thanks for keeping us in the loop, maybe update the old thread?
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
06-04-2021, 03:50 PM | #6 | |
And yes, very happy days ahead and summer has only begun. |
06-04-2021, 04:35 PM | #7 |
Great find - 1953 Ford Customline Tudor Sedan. Will be a great car when restored. Keep up the good work. |
06-04-2021, 03:48 PM | #8 |
The previous owner in the US changed the oil in the engine, replaced the ignition parts and got it started.
Since then I restored the wheels and changed the tires. Rebuilt the brakes and water pumps. Cleaned out the tank and carb. Changed oil in the trans. Replaced the headlight wiring with new stock looking harnesses from Dennis Carpenter and replaced some other wires in the rest of the car. Also found the reason it got parked, a worn fuel pump lobe on the camshaft so I went with an electric fuel pump for the time being to be able to drive it. |
06-05-2021, 05:50 PM | #9 |
Good find, grouse job on the wheels and keep us all up dated on the progress please.
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
06-06-2021, 06:41 AM | #10 |
Looks good you’ll have to make a video of it driving, take us for a ride in the Swedish countryside.
06-06-2021, 07:01 AM | #11 |
Thank you, I'll see if I can manage to make a video but here is a picture from yesterdays countryside drive.
06-06-2021, 07:03 AM | #12 |
Then this happened.
Don't no if I got a bad quality tube or if I messed up when installing it. The tires are for tubeless use but I decided to go with tubes since I don't really trust those rivets that holds the wheel together to be air tight but I might have to reconsider now. |
06-06-2021, 07:40 AM | #13 | |
I have tubeless tires on the stock riveted wheels on my '51 Fords. I have never had a problem with leaks. On the other hand, I chased a slow leak in one of the welded wheels on my Corvette for several weeks until I finally found it. Glad to see you're on the road. |
06-06-2021, 07:12 AM | #14 |
Mikko
Great looking 53! Yikes on the tire. Dont have that happen often nowdays?? I remember riiding in my uncles 52 Ford. Regards, Chris |
06-06-2021, 08:50 AM | #15 |
I will probably remove the tubes now.
Maybe seal the rivets with something on the inside? |
06-06-2021, 09:15 AM | #16 |
I'd suggest to just give it a try tubeless with the wheels as they are and monitor the pressures. If you find you are slowly losing pressure then look at adding something. Any air loss will be gradual and not sudden. Is the tyre damaged, or can it be used again?
I ran tubeless radials on my 58 GMC successfully. The only problem I had was on the fronts when they had tubes in. The tubes get abraded by the tyres as they flex. |
06-06-2021, 10:41 AM | #17 |
I will remove the tire from the rim tomorrow and inspect it.
Hopefully I can use it again, expensive to buy a new one. |
06-06-2021, 04:35 PM | #18 |
I have run tubeless tires on old riveted Ford rims on several vehicles for 20 years. The most I have done was sand blast and paint the inside of the rim to prevent leaks, and I have never had a leak. I'm about to put the third set of radials on my 53 sedan since the tires are aging out (current 9 year old Diamondback tires with 22K miles, many at 70+ mph).
I'm also attaching a couple pictures of my 53 with tubeless radials since I also need to remember how to post pictures on the Ford Barn. I hope you don't mind. Last edited by 38 coupe; 06-06-2021 at 04:45 PM. |
06-06-2021, 05:13 PM | #19 |
Running tubeless tires on my '53 stock wheels. No issues. All hold pressure just fine.
06-07-2021, 10:33 AM | #20 |
Seems like my wheel holds air pressure fine too.
Just need to remove the tubes from the 3 remaining wheels now, hopefully I'm back on the road by the weekend. |
